Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   B20VTEC dowels (https://honda-tech.com/forums/tech-misc-15/b20vtec-dowels-879857/)
Pandahatch May 29, 2004 03:50 PM
B20VTEC dowels
I'm trying to go a different route putting my motor back together and I'm decidiing between dowel pins. I have the GE pins and they are a good idea, but you have to open the headgasket to fit them in the block. With the OEM pins you have to drill the head but you don't have to mess with the gasket. What does everyone use or reccommend? I'm thinking my leak might have something to do with this. Also what headgasket is everyone running? I've used GE and OEM B20B and have had the same problem.
Modified by PandaHatch at 1:23 AM 5/30/2004
Pandahatch May 29, 2004 07:44 PM
TTT
torr May 29, 2004 08:19 PM
Re: (PandaHatch)
i used a oem b20 headgasket and moved and drilled the dowels. no problems
Pandahatch May 29, 2004 10:42 PM
Re: (torr)
It's just really pissing me off, no matter what I do it leaks. I'm gonna try using the OEM head bolts.
dfoxengr May 30, 2004 08:43 AM
Re: (PandaHatch)
you shouldnt really reuse rod bolts. id stick with the GE dowels and an OEM HG
Pandahatch May 30, 2004 09:59 AM
Reuse rod bolts...? Huh I don't know where this came in. I have new OEM GSR HEAD bolts.
dfoxengr May 30, 2004 01:07 PM
Re: (PandaHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaHatch &raquo;</TD></TR><TR><TD CLASS="quote">It's just really pissing me off, no matter what I do it leaks. I'm gonna try using the OEM head bolts.</TD></TR></TABLE>
thought u were talking about the old ones. http://images.honda-tech.com/set1//smile/emcrook.gif
bull2k4 Jun 5, 2004 09:17 PM
Re: (hybridvteceg)
i just got finished building my b20vtec....moved up from an lsvtec. i used the ge dowels with arp head bolts and the cometic head gasket for a b20 same as oem b20 head gasket but it's 85mm bore....so for you the oem b20 gasket should work great..
