Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   B20 buildup? (https://honda-tech.com/forums/tech-misc-15/b20-buildup-414278/)
Aquafina Feb 12, 2003 07:58 PM
B20 buildup?
How much does it cost to build a b20 up to a "stock" level?
Also, would it have more power with a GSR or ITR head?
How much more does a b20 weigh than a b18c1?
DevinW Feb 13, 2003 07:16 AM
Re: B20 buildup? (SuperStreetRX7)
Um..Building up a B20 would mean it's not stock anymore...If you mean how much does it cost to get one running as a swap, well you'll need: tranny, Intake manifold, exhaust manifold, flywheel, clutch, etc...it's not always cheap.
It's most likely that a b20 will more more power N/A with a VTEC head than without one. However, B20 non-VTEC engines can make 160-170 whp and 150 ft-lbs with bolts-ons and nice cams.
I'm not sure if a b20 would weigh less/more than a GSR, but I have heard that B20s may be a bit lighter that B18Bs.
juicedricer Feb 13, 2003 07:53 AM
Re: B20 buildup? (DevinW)
does the B20 mounts fit the engine bay w/ stock mounts?
DevinW Feb 13, 2003 08:09 AM
Re: B20 buildup? (juicedricer)
I'm not too sure on the mounts as I haven't got them in yet...here's an old post that goes into detail on what you'll need: https://honda-tech.com/zerothread?id=325978
Blaze45 Feb 13, 2003 12:22 PM
My B20 weights 325.
Blaze
