Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   b20 build up? LS or b20? (https://honda-tech.com/forums/tech-misc-15/b20-build-up-ls-b20-419613/)
who00knows Feb 18, 2003 08:40 PM
starting my b20/vtec build up. I need some help with a parts lists........i figured might as well learn from people who have done it..........gonna piece together a complete motor so anything goes............PLEASE GIVE ME OPINIONS!
dfoxengr Feb 18, 2003 09:51 PM
Re: b20 build up? LS or b20? (who00knows)
bored/sleeved LS
who00knows Feb 19, 2003 04:20 AM
Re: b20 build up? LS or b20? (hybridvteceg)
Why would you say that over a b20?
DevinW Feb 19, 2003 07:54 AM
If you are going to resleeve an engine, go with the LS and resleeve it to 2.0. If you are not going to touch the engine sleeves, get a B20... https://honda-tech.com/forums/images/smilies/emthup.gif
This is becuase you can get an LS block for much cheaper than a B20 block.
sgT Feb 19, 2003 08:56 AM
b20 sleeves are weak. i have seen too many crack to risk using one.
better to sleeve a b18
Kataku2K3 Feb 19, 2003 09:02 AM
Re: b20 build up? LS or b20? (sgT)
Never have actually seen B20's crack personally but i would go with the sleeved LS... hehehe http://www.goldeneaglemfg.com/sleeves.htm
dfoxengr Feb 19, 2003 10:11 AM
Re: b20 build up? LS or b20? (Kataku2K3)
yeah supposedly b20 sleeves suk
Kataku2K3 Feb 19, 2003 10:45 AM
Well the reason I say this, I have several friend's running high compression CRVTEC's anywhere from 12.0:1-12.5:1 and they are all stock sleeved and holding up just fine for the past year... 12.62@107 full interior EK, and a 12.93@107 full interior Teg.... Both are just running high compression JE pistons, one has aftermarket rods, both run Portflow GSR head w/ SK2 IN manifold, sprockets, the EK just has a CTR IN cam (GSR EX), the Teg is running SK2ST2 cams, both run RC 310's (which are too small), the Teg is running Hondata, and the EK is running an ITR ECU and VAFC... The EK's never been dynoed, ONLY tuned by feel, and the Teg made 230whp and 152 torque... Sorry i went on and on and on but yea.. I'm bored still.. hahaha...
EvilIntegrationLS Feb 20, 2003 08:15 AM
yea, i've heard similar comments.
ExospeedAMcrx Feb 20, 2003 08:28 AM
Here’s the break down as far as cost efficiency of choosing a b20 or Ls block.
For sleeving applications. Better to use an LS block since It can be bored out to a 2.0L anyway.
Cost is roughly $250 for LS block plus sleeving, we have that at $880.00 for bore/hone/hot tank/deck.
So for about $1130 you get a sleeved 2.0L block or whatever bore size you desire.
If not getting sleeved, the B20 block is a good choice since they can be had for like $750-900.
Overall, it all depends on how far you want to take your motor to. If not going to redo the internals, and you aren’t really going to race it often, the basic b20 is good enough. But if you are going to be adding turbo, changing internals, high compression, etc, might as well invest an additional $300 or so in getting a stronger reinforced sleeved block.
Also Sleeved B20 block is waste of money unless the block is already messed up in the first place. Get an LS.. theyre much cheaper.
Wil
aHOLE Feb 20, 2003 12:25 PM
what is your budget? why not a vtec bottom?
ExospeedAMcrx Feb 20, 2003 02:18 PM
Re: b20 build up? LS or b20? (aHOLE)
GSR bottom will set you at around $500-700 just for the block. plus sleeving, $1400-1600 total. Kinda pushes it to the non-budget level.
