Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   b18c1 sensor help (https://honda-tech.com/forums/tech-misc-15/b18c1-sensor-help-3180612/)
nogodracer23 Nov 18, 2013 05:06 PM
b18c1 sensor help
ok some of you guys are gonna read and say what the hell, but i need some help figuring out a sensor, if youre looking at the motor, you have the vtec solenoid and under that you have the coolant temp sensor, and theres one kinda next to it and below it and i looked online and threw the haynes manual and i cant find out what it is. so i know theres some guru's on here that can help me.
kyden Nov 19, 2013 05:38 AM
Re: b18c1 sensor help
picture? on the head there should be the coolant temp sensor and the sender for temp gauge in your cluster.
HondaPartsHero Nov 19, 2013 11:48 AM
https://i859.photobucket.com/albums/..._gsrplugs1.jpg
Colin Nov 19, 2013 11:51 AM
^ Terminology in that diagram doesn't really match the Helms. So just to clear things up:
ECT Switch = Fan switch
ECT Sensor = TW Sensor
ECT Sending Unit = Coolant Temperature
UGAVtech Nov 19, 2013 11:56 AM
Originally Posted by HondaPartsHero (Post 49310469)
Good reference!
HondaPartsHero Nov 19, 2013 02:39 PM
Fan switch = cooling fan switch
Coolant temperature = sends signal to gauge cluster
TW sensor = sends signal to ECU
nogodracer23 Nov 19, 2013 03:11 PM
HondaPartsHero youre the shit thats exactly what i needed
HondaPartsHero Nov 20, 2013 12:10 PM
Here's another in case you need it
https://i859.photobucket.com/albums/..._gsrplugs2.jpg
