B18c Making Noises
Ok i started my car up this afternoon to go to work and i noticed it was ticking quite loudly and as i reved it up it got louder and faster. I was told by a friend that it was something with the valve timing??? If someone could give me some basic idea of what the problem might be or what i could do to repair it if i would have to take it to a repair shop or if i could do it myself... any help would be awesome but i searched and didnt find anything!
Thanks in advance. Josh R. |
Re: B18c Making Noises (delsol93guy)
Ticking probably wouldn't be valve timing. More likely your valve clearances need to be adjusted.
Re: B18c Making Noises (JimBlake)
What would it take to adjust them? A repair shop or could i do it?? What about the lifters would those be bad or not? More help please!!!
Josh R. |
Its not that hard if you have a manual, you also need a feeler guage and it make a lot easier if you get the valve adjustment tool from snap on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol93guy »</TD></TR><TR><TD CLASS="quote">... What about the lifters would those be bad or not?</TD></TR></TABLE>That's what valve adjustment is all about... You don't have hydraulic lifters, it's got rocker levers with screw/nut adjusters on the end.
On your DOHC VTEC head the adjusters are down low where they're a little hard to reach. The proper tool is nice, just imagine a really long deep 10mm socket with a handle. Stick a screwdriver down the middle where the ratchet handle would have been. Otherwise, maybe there's enough room for a crows foot socket? There's some threads about taking an open-end wrench & bending it so it works like a crows foot. |
| All times are GMT -8. The time now is 07:21 AM. |
