b16a1 fluctuating idle 200 rpm . HELP
my idle fluctuates 200/300 RPM
COLD don't fluctuates hot engine fluctuates 30 seconds after starts running ( the first 30s when is hot don't fluctuates ) I've done: -IACV- clean 2 times, i close the IACV and engine still fluctuates -FITV- clean 2 times, i close the FITV and engine still fluctuates -vacuum system- the vacuum system was verified with proper gun, and check the tubes, tube are like new check with proper smoke equipment (smoke will emerge on leaks) test it with carburettor cleaner -TPS- tested 3 - all tuned to 0.45v open , 4.55V closed -TB- clean and tested 2 -IAT- temperature sensor admission was clean -Bleeding Air In Cooling System- done several times -ECU- tested 2 stock ECUs -valve lash- in 0.15mm ex 0.20mm -ignition timing- 15 deg. -engine timing- its ok ( set properly ) -cams are proper in alignment -compression check- cylinder 4 - 11.5 cylinder 3 - 12.5 cylinder 2 - 11.5 cylinder 1 - 12.5 -spark plug wires- 3 sets tested (2 used, 1 new NGK) -spark plug- tested 2 sets (NGK BKR6E-11 || 5304 Denso Iridium IK20) TESTS with STRANGE results if i unplug the TPS idle stops fluctuates if i unplug a spak cable (any one) and plug again idle stops fluctuates what more can i do ? PROBLEM FIX (i think my problem was the o2 sendor harness to the ecu) i decide to change my ecu pw0-x00(obd0) to obd1 so, i made this changes. -b18c4 exhaust manifold -p28 ecu (chipped with p30 map) -td-86u dizzy with obd1 plugs -4 wires o2 sensor and now with o2 sensor enable i dont have fluctuating idle THANKS TO ALL !!! for helping |
Re: b16a1 fluctuating idle 200 rpm . HELP
did this today, and didn't solve my idle problem :(
-valve lash in 0.15mm ex 0.20mm -ignition timing 15 deg. -engine timing its ok ( set properly ) -cams are proper alignment -compression check cylinder 4 - 11.5 cylinder 3 - 12.5 cylinder 2 - 11.5 cylinder 1 - 12.5 |
why 15 degrees ignition timing?
it should be same as your engine timing which should be 16.5 |
have you checked your fpr they do go out sometimes
check coil it gets damaged by heat and looses charge sometimes and then slowly dies and wont start one sure sign is rpm drop at the traffic light |
what is FPR ?
my engine manual / service says the ignition timing is 15 +-2 ( 13 , 14 ,15, 16 , 17) tried on 16º .. didnt solve idle problem |
the td22u distributor is one thing i couldn't test, because i have no access to other one :(
test the coil and ignitor
u have a chipped ecu or stock? its idling at 1100 rpm when it should be at 750-850rpm your coolant temp looks like only1/4 if that's as high as it goes that means your thermostat is stuck open(failsafe) which means the engine is not at full operating temp high idle can also mean vacuum leaks and they are sometimes not very easy to find |
check with proper smoke equipment (smoke will emerge on leaks) test it with carburettor cleaner i have no vacuum leaks sorry about the coolant ( to use s2000 cluster it needs a converter for speed ans coolant, i sent the converter to tuned the speed to have the REAL GPS speed, so the coolant is working good, but without the converter the coolant dont work ) |
i made other approach...
i decide to disable the first oxygen sensor on the ECU ( on BRE ) idle problem solve, with 1st o2 sensor DISABLE and 2nd O2 ENABLE (i think thats why the idle start after 30s, because is when ECU starts making adjusts on AFR) do i have the 1st o2 sensor defective ? my ECU gives me NO errors is normal to have a defective sensor with no ECU error ? could be a exhaust manifold leak ? a leak on 1st o2 sensor hole ? just cleaning solves the problem ? https://dl.dropboxusercontent.com/u/...t_manifold.jpg |
unless the magic idle adjustment fairy came and turned the idle adjustment screw while you were sleeping, ignore what this guy said and fix the actual problem instead of creating another one
@mfreeman
isnt the idle screw, that was the first thing i did, and i tried 2 TB, so 2 screw ;) |
Originally Posted by holmesnmanny
(Post 49751193)
Originally Posted by gabrielsousa
(Post 49751415)
do you think is the 1st o2 sensor of a 1 , 4 injector ? after replacing the oxygen sensor you will need to reset your base idle if you fiddled with the idle adjustment screw already |
my car is CRX EE8 EDM 1991 b16a1
found out that the second o2 sensor had the wire cut
replace the second o2 sensor (for a used one), and didnt solve my problem |
