B16a timing belts
What are the differences between the different year B16a timing belts?
I need one for my OBD0 B16a.... Is the 94+ Del sol DOHC Vtec and the 00 Civic Si DOHC Vtec the same? Search didnt help Thanks |
Re: B16a timing belts (hondahelp)
Re: B16a timing belts (snatch)
All the B16A timing belts are the same. I used a 99 Si belt on mine.
Do you have an obd0 1st gen b16a as well? Thanks |
And 99-00 civic si dohc vtec are the same right?
Yeah, mine is an OBD0 JDM first gen. The obd0 b16 and the b16 in the del sol and 99-00 si are all the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahelp »</TD></TR><TR><TD CLASS="quote">What are the differences between the different year B16a timing belts?
I need one for my OBD0 B16a.... Is the 94+ Del sol DOHC Vtec and the 00 Civic Si DOHC Vtec the same? Search didnt help Thanks</TD></TR></TABLE> All JDM & US B16A timing belts are the same in design & length and are compatible with any year B16A engine. If you find different OEM part numbers for B16A timing belts, its because they come from a different vehicle. ie. DOHC Delsol, 99-00 Si coupe. So, you can use a 99 Si timing belt on your 1st gen B16A engine if that's what yer wondering. https://honda-tech.com/forums/images/smilies/emthup.gif |
| All times are GMT -8. The time now is 03:30 AM. |
