Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   B-series Engine Mount Question (https://honda-tech.com/forums/tech-misc-15/b-series-engine-mount-question-454163/)
RyanAutry Mar 25, 2003 04:03 PM
Is it necessary to have the A/C Mount if you don't have AC? I noticed this car doesn't.
http://www.jdmcivic.com/photopost/da...abunai-med.jpg
[Modified by RyanAutry, 5:04 PM 3/25/2003]
TimoneX Mar 25, 2003 06:26 PM
Re: B-series Engine Mount Question (RyanAutry)
Well your pic doesn't work, but the AC mount has that motor mount coming off of it, more like a stabilizer since it doesn't bear a huge amount of weight, but I'd bet your motor will torque a bit more w/o that mount costing you a bit of power.
Nameless RB26 Mar 25, 2003 06:29 PM
Re: B-series Engine Mount Question (TimoneX)
Yah you need it. Not a mount, but a bracket.
AC compressor bolts onto it. https://honda-tech.com/forums/images...es/emsmile.gif
RyanAutry Mar 25, 2003 10:26 PM
https://home.attbi.com/~ryanautry/misc/noacmount.jpg
RyanAutry Mar 25, 2003 10:27 PM
Re: B-series Engine Mount Question (Nameless)
Well I don't have AC. https://honda-tech.com/forums/images...es/emdgust.gif
RangerDan Mar 25, 2003 11:05 PM
Yeah you need it on most applications. With some 5th Gen civics without it the engine will sometimes hit the hood under power.
Its not really a weight bearing mount but it keeps the engine from rocking back and forth when punched.
BROOD Mar 26, 2003 04:45 AM
You should run all the engine mounts...including the two forward torque mounts. They are there for a reason. https://honda-tech.com/forums/images/smilies/emthup.gif
blufke Apr 29, 2003 02:48 AM
Re: B-series Engine Mount Question (SLPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLPR &raquo;</TD></TR><TR><TD CLASS="quote">You should run all the engine mounts...including the two forward torque mounts. They are there for a reason. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
for a hood denting reason.
94CivicSi Apr 29, 2003 06:27 AM
Re: B-series Engine Mount Question (blufke)
If you don't have AC, you can run the Integra P72 AC bracket. They're much more common than the Del Sol P54 bracket which accepts the Civic compressor and therefore, much cheaper. I have an extra P72 WITH the mount if you're interested.
