Axle Problems. possible answer inside:
i'm trying to make this as generic and with as many key words as possible so someone that needs this info can find it.. so pay no attention to the words at the bottom of the thread
i searched for over 6mos to find out why my passenger side axle wouldn't go all the way into my tranny. it stayed out nearly 1/4" and leaked tranny fluid like nobody's business. quick note: Y1 tranny/hydro conversion. i had most people tell me that all axles are the same, a couple said "there MAY be a difference... one IS cable and the other hydro", but nobody could give me a difinitive answer. nobody could tell me FOR sure why my axle wouldn't go all the way in. well, a friend stopped by while i was wrestling this thing for the 100th time. "oh, yeah. cable axles have longer splines than the hydro tranny" wtf?? sure enough. that was it. i searched HT for MONTHS! i found similar posts asking for help, but were usually followed by: "you have a pm" "hey, that fixed it. thanks!" or "i got it. nevermind" either way, NOBODY ever posted the answer. well, here's a pic: http://mywebpages.comcast.net/kaj750/axlecompare.JPG this shows the difference. in short anyone with a cable tranny, you need the axle with the FULL LENGTH splines. the others are hydro https://honda-tech.com/forums/images/smilies/emthup.gif that's it. someone please archive this thread? axle, different length, doesn't fit, hydro, cable, tranny, leaking, B-series, splines |
nice post. I'm sure your struggle will help many others
Re: (david90)
what is hydro and cable tranny?
Re: (david90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 »</TD></TR><TR><TD CLASS="quote">what is hydro and cable tranny?</TD></TR></TABLE>
hahaha. veeeeeery funny https://honda-tech.com/forums/images...s/emsmilep.gif yeah, hopefully someone will find this useful. i know i would have!!! |
so is it possible to use the axle with FULL LENGHT splines into a hydro tranny without any problems?
Re: (Turbo_Siii)
i'm told "no" 'cause it "rattles" around inside, but i haven't tried.
Re: (kaj)
so what car is that axle from with full splines? cause i have a CRX with a b16a in it and my axle look like the hydro one
on my 93 ls with a cable trans the passenger side axle has the short spline(left pic) and the drver side axle has the long spline( right pic). maybe yours were just in backwards...iuno
Re: (projectTeG)
tried to switch them when i was desperate to solve the problem. switching didn't work https://honda-tech.com/forums/images/smilies/emsad.gif
Re: (kaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaj »</TD></TR><TR><TD CLASS="quote">tried to switch them when i was desperate to solve the problem. switching didn't work https://honda-tech.com/forums/images/smilies/emsad.gif</TD></TR></TABLE>
ok so is the one with the full splines a passenger axle? if so from what car? year make and model would be great thanks |
Re: (b16crx1)
'92 civic, but i have an old Y1 tranny (88-91, jdm, i believe)
Re: (kaj)
but isnt a 92 civic a hydro tranny?
92 is a hydro tranny but you can still use the cable tranny into the 92up.
Re: (Turbo_Siii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_Siii »</TD></TR><TR><TD CLASS="quote">92 is a hydro tranny but you can still use the cable tranny into the 92up.</TD></TR></TABLE>
exactly. not thrilled about the whole hydro coversion thing, but the gearing is nice and it DID come with a Quaife LSD. |
Re: (kaj)
the axle you have on the right in the pic is a 90-93 teg DRIVERS side axle..
90-93 had a female intermediate shaft and 94+ have a male..it could be the diff..I have heard of issues like this before with axle spline on quaifes.. Iam using 90-93 axles (all 3) in my 95 gsr tranny in my 99 HB |
Re: (99Hybrid_Hatch)
okay. this is an FYI for people with Quaif LSDs then https://honda-tech.com/forums/images/smilies/emthup.gif
as long it helps SOMEBODY, then cool. |
| All times are GMT -8. The time now is 03:55 AM. |
