ARP Head bolts
ARP head bolts are the same for a b16 and GSR correct?
Re: ARP Head bolts (straightline)
c'mon
No, they are different. They are Studs, not bolts too. The GSR studs are at least 7mm longer than B16 studs.
Re: ARP Head bolts (AzSi22)
so if I have a Ls Vtec with a b16 head I would have to use b16 studs? the GSR ones wouldn't work?
you need type R studs gsr may work but I dont know for sure B16 are too short
anyone know for sure which ones I would need to use?
LS Vtec with B16 Head I ordered b16, so I would like to know for sure if they will work or not |
I think you should of got the GSR/Type R ones.
GSR and Type R are the same size. Any LS or CRVtec need to use GSR/ITR studs.
Yup you need gsr/itr studs, b16 are to short. Ls studs are not long enough for the middle two.
Re: ARP Head bolts (dwn-shift)
alot of people use the b16 studs, but the b18 studs are the way to go.
| All times are GMT -8. The time now is 06:00 AM. |
