Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   another idle thread (https://honda-tech.com/forums/tech-misc-15/another-idle-thread-671998/)
Teknic73 Nov 8, 2003 12:44 PM
another idle thread
posted this in the Integra forum, but i barley got any responses. hopefully i'll have more luck here.
my car is possessed and im certain of it. the f'kn thing has a mind of it's own and does weird things. I'm just looking to see if i can get some answers.
the car for a while now has had idle problems, as far as in the mornings it revs quite high (2000rpm) but after a couple of minutes it goes down to about 750rpm. Now all of a sudden it's reving at about 3000rpm when cold and dies down to about 1500rpm at normal temp, which is still high and very annoying at stops. I'm assuming it's my FITV, but I'm not sure. any type of feedback would be appreciated. tia .
Teknic73 Nov 9, 2003 11:02 AM
Re: another idle thread (Teknic73)
ttt
NonAutoX Nov 9, 2003 05:35 PM
Open up the FITV, and see if the wax plunger is cracked/old/broken I think it costs about 35 new from a dealer.
gsrcivict Nov 9, 2003 08:51 PM
Re: another idle thread (NonAutoX)
I have the same problem only mine throws a code 14. Im so ready to blow up my car cuz Ive already switched out the iacv 2ce and its still doing the same thing! https://honda-tech.com/forums/images/smilies/mad.gif
kinvid22 Nov 11, 2003 12:44 AM
My B20 idles at 2K in the morning too, after a couple of mins, it chills at 600...hmmmm...sounds bad eh?
gsrcivict Nov 13, 2003 08:24 PM
aight fellas just a lil update on my idle problem..........ITS FIXED!!!!!!!!!!! YEAAAA!!!!!!! boi am I glad that shit stopped. all along it wasnt the iacv or vacum lines, the intake manifold gasket was pretty bad. it was leaking all the way around and I gues it caused the ecu to think it was the iacv. weird if you ask me but I replaced the manifold gaske and poof! no more problems
Teknic73 Nov 13, 2003 10:13 PM
Re: (gsrcivict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivict &raquo;</TD></TR><TR><TD CLASS="quote">aight fellas just a lil update on my idle problem..........ITS FIXED!!!!!!!!!!! YEAAAA!!!!!!! boi am I glad that shit stopped. all along it wasnt the iacv or vacum lines, the intake manifold gasket was pretty bad. it was leaking all the way around and I gues it caused the ecu to think it was the iacv. weird if you ask me but I replaced the manifold gaske and poof! no more problems</TD></TR></TABLE>
did u take it to a shop?
