Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   ABS Removal Harness? (https://honda-tech.com/forums/tech-misc-15/abs-removal-harness-3051433/)
Steeve_Civic Apr 28, 2012 11:47 PM
Hello,
I need to remove the ABS harness.
Is there some picts on diagram to help me?
I removed all Orange Plugs but the harness seems to go behind the dashboard?
Can I cut it witout any problems?
Thks
Steeve_Civic May 1, 2012 01:41 PM
Re: ABS Removal Harness?
Can I cut all Orange connexions without problem with the ECU?
Jdm Accords May 5, 2012 01:26 AM
it's seem no one unable to answer you Question... me neither can't help you... i just suggest you try to surf at google.:|
Steeve_Civic May 7, 2012 08:09 AM
sniff, no one has ever removed his OEM ABS harness?
Thks
lsturbo33 May 7, 2012 12:30 PM
I did in my 97 Integra. I removed all the wires connected to the orange plugs and unpinned them at the ecu or wherever the went. It's been like 3 years since I did it but I didn't have any trouble after wards.
lsturbo33 May 7, 2012 12:31 PM
The abs has it's own ecu if I remember right. I think it's in the passenger side quarter panel area.
kyden May 7, 2012 12:42 PM
i suggest you grab a helms manual and trace the wiring. then you'll know what wires you can or can't remove.
