92 eg hatch si fuel pump won't prime no spark
Hey guys, I have a 92 si d16z6 where after a rain it takes a while (with the ignition on) for the fuel pump to prime. I've checked for voltage to the pump and thereally isn't any. There's also no spark.
After leaving the switch on for a few minutes the fuel pump would prime then the car would start just fine. It rained pretty hard last night and the car won't start at all. Something is obviously getting wet but I don't know what??? Any suggestions??? Thanks in advance! |
Re: 92 eg hatch si fuel pump won't prime no spark
Does any other electrical work, do all the cluster lights turn on? 94
Can you get a hold of a second ecu to test with? i had an ecu that every time it rained or humidity got really high it would take a loooooong time to prime the fuel pump and turn everything on. Turned out there was something wrong with the fuel injector self test circuit and humidity made it worse...
