91 HF with b16a swap....speedometer doesn't work problem
The speedometer worked before the b16 was swapped in. I don't know what the shop did but now it doesn't work. What could the problem be? Am i suppose to swap out the speed sensor??
Re: 91 HF with b16a swap....speedometer doesn't work problem (tazmoe)
Yeah i have the same prob you need your stock vss back because its cable and the b16 is electrical
