2 questions obd1 harness from d16 and injectors.... help???
Ok first off, here soon i will be doing a swap gsr (obd1) into del sol (obd1 d16) so i plan on using the harness from the d16 that is in the delsol right now. Will this work? And if it dosnt what mods will i have to do to make it work. I have never done a swap and tried to utilize the harness. Soooo i dont see why it wouldnt work seeing that the d16 has vtec and oil pressure wiring etc that you woul need for the gsr wiring. Let me know. OH and does anyone know the diffferences between gsr injectors and type r? any differences at all? im guessing they are the same but i want to find out.
thanks in advance
thanks in advance
B16aCRXSi
34
09-01-2008 07:29 PM
