Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   1st gear keeps on shooting back out (https://honda-tech.com/forums/tech-misc-15/1st-gear-keeps-shooting-back-out-244669/)
3rdGteg Aug 12, 2002 11:09 PM
Re: 1st gear keeps on shooting back out (tinkerbell)
Mista Bone, I've been shopping for my 1-2 shift fork and 3rd gear synchro, but I don't know what category to look under for the synchro (mainshaft, countershaft, or what?--Don't list synchro for where I'm looking at). Can u check out this sight " http://www.acuraautomotiveparts.net " and possibly point out which part do I need for that grinding in 3rd gear--I think I found the shift fork already. My tranny is a 94-97 gsr. Thanks. http://images.zeroforum.com/smile/emthup.gif
[Modified by 3rdGteg, 8:10 AM 8/13/2002]
3rdGteg Aug 13, 2002 11:24 AM
Re: 1st gear keeps on shooting back out (3rdGteg)
ttt
3rdGteg Aug 13, 2002 10:54 PM
Anyone?
3rdGteg Aug 14, 2002 11:29 AM
3rdGteg Aug 16, 2002 10:15 PM
Anyone? I know someone out there has fixed a synchro before....I just need help finding the part at http://www.acuraautomotiveparts.net
3rd gear synchro or whatever I need to change to fix that grinding in 3rd.
(94-97 Gsr tranny)
jl2teg Aug 21, 2002 08:50 AM
I broke a shift lever in my tranny. So I pulled it out of the car. took the trans. apart. It wasn't a piece of cake but, nothing that can't be done. while it was apart I replaced all the bearings and seals added lsd and replaced the shifing devices this cost me about 1,000 dollars and took me a few months you can do this with basic tools and press to change the bearings i orderd the parts from my local acura dealership if you call them they will send you an exploded view of the tranny good luck
jl2teg Aug 21, 2002 08:54 AM
Re: 1st gear keeps on shooting back out (jl2teg)
I also replaced the scyncro's they are very costly It was a great learning experince but cheeper to buy a used tranny.
gavhowe Aug 22, 2002 03:35 AM
Re: 1st gear keeps on shooting back out (miahmouse)
Mine is doing the same jumping out of second. which bushes do i need on this bar.
JHill Aug 22, 2002 06:32 AM
Acura only sells the gearsets, they do not sell individual synchros. In order to do both shafts, you need to spend a total of about $800 for the three different sets in a b series transmission.
I had the same problem with the popping out of first, and it was not the fork which goes around the gear changer on the shaft, but the little fork mechanism that the shifter moves to control all the forks. (If you look at the Helms, you will see what I am talking about). It is one of the first things that the Helms tells you to inspect for wear.
3rdGteg Aug 22, 2002 10:29 PM
Re: 1st gear keeps on shooting back out (JHill)
Thanks for the replies; now I'm still debating upon spending my money on rebuilding this tranny or try and buy another used one (which I'm very concerned about since I got ripped off with this p.o.s.).
b18c1civic95 Aug 23, 2002 10:38 PM
have u had the motor for awhile..........or just did a swap? cuz if the fluid is almost gone it will pop out of gear also but i think its like 3 and up.........i was told my car had fluid and being dumb enough i drove forever and it would pop out constantly on the freeway....... but i dont know about first gear...... probably what they said
3rdGteg Aug 23, 2002 10:51 PM
Re: 1st gear keeps on shooting back out (b18c1civic95)
Well now, I'm even having more and more problems with this stupid tranny. Now sometimes it don't fully engage into first and second; it just grinds and grinds lightly and won't move when I press on the gas pedal--just a grinding noise.
And EVERY single time it's in 5th gear now, it makes this high pitch whining noise which gets louder as the speed gets higher. http://images.zeroforum.com/smile/emsad.gif http://images.zeroforum.com/smile/emhammer.gif http://images.zeroforum.com/smile/emthdown.gif
jl2teg Aug 30, 2002 05:40 PM
bullshit acura sells individual scyn. they come in sets 1and2 for around 200 3and4 200 and 5 is about 300. have had expirence with this my fork broke after spanking a gsr with my 75shotls http://images.zeroforum.com/smile/acura1.gif http://images.zeroforum.com/smile/acura1.gif http://images.zeroforum.com/smile/acura1.gif
