Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   02 crv block? (https://honda-tech.com/forums/tech-misc-15/02-crv-block-200173/)
tECH_ Jun 3, 2002 04:10 PM
02 crv block?
Anyone know the K24 rod length, or rod/stroke ratio?
thanks
allmtr Jun 3, 2002 08:13 PM
Re: 02 crv block? (tECH_)
87.0 mm bore and a 99 mm stroke.
9.6:1 CR
4.765:1 final drive
6500 redline
160 hp 162 tq
2354 cc
composite two stage intake manifold
kinesistech Jun 4, 2002 12:21 AM
Re: 02 crv block? (allmtr)
Put that block in a rsx type s
biggdogg Jun 4, 2002 11:19 AM
Re: 02 crv block? (kinesistech)
no in a new civic hb with the type s head jeeeeeez man were talkin 240 hp and 200 ft lbs http://images.zeroforum.com/smile/emcrook.gif http://images.zeroforum.com/smile/emthup.gif
tECH_ Jun 4, 2002 02:23 PM
9.6:1 CR
4.765:1 final drive
6500 redline
160 hp 162 tq
2354 cc
Thanks for this info, but what i'm looking for is the rod length or rod/stroke ratio.
Rembrant Q. Einstein Jun 4, 2002 04:20 PM
the K24 has a 19mm taller deck height compared to the K20s, which would make up for some of the 13mm stroke increase. I could not find the rod length. I don't know if the compression heights are the same. Do you know the K20 rod length?
Rembrant Q. Einstein Jun 4, 2002 05:31 PM
Re: 02 crv block? (Rembrant Q. Einstein)
the place to call that might know would be http://www.kingmotorsports.com , they are supposedly building a 2.4L RSX Type S project car, using the K24 block, so they might be inside the blocks already and have stuff measured out.
Daemione Jun 4, 2002 05:35 PM
Re: 02 crv block? (biggdogg)
And piston speeds approaching the speed of light . . . . . .
Would take a arse load of work to be reliable enough for a street car.
tECH_ Jun 5, 2002 07:05 PM
I will give them a call, thanks for the help.
