Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Tech / Misc (https://honda-tech.com/forums/tech-misc-15/)
-   -   $4000 to spend on an engine.. (https://honda-tech.com/forums/tech-misc-15/%244000-spend-engine-590232/)
jbell Aug 12, 2003 12:41 PM
whats the fastest, reliable engine i could have for this..
someone mentioned a b20 turbo.. but im not sure.
Spade Aug 12, 2003 01:01 PM
Re: $4000 to spend on an engine.. (jbell)
Read sig https://honda-tech.com/forums/images...es/emsmile.gif
Seriously, if you break it, you'll have money to rebuild it.
jbell Aug 12, 2003 01:03 PM
Re: $4000 to spend on an engine.. (Spade)
is there a way to make it reliable?
Kamin Aug 12, 2003 01:03 PM
b16+boost
i could do that for about 4k with a custom turbo kit.
jbell Aug 12, 2003 01:04 PM
Re: $4000 to spend on an engine.. (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">b16+boost
https://honda-tech.com/forums/images...es/emsmile.gif </TD></TR></TABLE>
think thats the fastest? think you can swap it too?
Kamin Aug 12, 2003 01:10 PM
actually it should be
b16 OR ls turbo.
LS + boost would be a sick combo.
looking about 2500$ shipped for a LS swap, and you can do a DIY turbo kit for ABOUT 2000.
g00se Aug 12, 2003 01:44 PM
b20 turbo is good, but you might actually find ls engines cheaper and probably more plentiful. Plus you might have some extra cash to play around with later if you went with the ls turbo..
Kamin Aug 12, 2003 02:01 PM
Re: $4000 to spend on an engine.. (g00se)
actually the b20 is probably the worst stock platform honda engine for boost
the individual sleeves it has are notoriously weak with boost.
jbell Aug 12, 2003 02:10 PM
so... stock ls engine + boost?
say.. greddy kit off ebay?
Kamin Aug 12, 2003 02:13 PM
eh i would piece together my own kit.
jbell Aug 12, 2003 02:40 PM
any reason why?
Kamin Aug 12, 2003 02:47 PM
you can build it to your specific specs and final goals.
fox297 Aug 12, 2003 03:14 PM
My friend has a complete turbo kit he's looking to get rid of. He was going to put it in his 95 teg, but decided to go all motor instead.
Calavera Aug 12, 2003 06:30 PM
Re: $4000 to spend on an engine.. (fox297)
or buy a used fully built engine listed in the classifieds...if you wait long enough, theres bound to be one or two really good ones appearing in the classifieds section. But thats such a pita.
But LS-T is just as (if not better) good. Either way, you can have a 200ish whp engine. https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif
