$2500 what engine to get?
what to do what to do..
with 2500.. what would be my best bet.. a built b16 a stock gsr a ls/vtec a very build d16 |
what car is it going in?
Re: (blo2ck)
del sol. pre-95.
Re: (jbell)
H22 :D
Re: $2500 what engine to get? (jbell)
ill sell you my old vg30dett.... all you need is seals, timing belt, and accessory belts..... oh yeah, and rods, pistons, a block, a crank, and a oilpan.... it looks good from the outside though!! only a couple of small holes... http://images.honda-tech.com/set1//smile/emcrook.gif think of it.... you could be the first guy with a twinturbo 300zx engine in your honda! https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
a built b16 -Maybe a stock one.
a stock gsr -Think again. a ls/vtec -Nope. a very built d16 -boosted D16 is very achievable with that amount. You still need to figure in the cost of replacement parts, (Timing belt, water pump, misc hoses, tune up parts, etc.) shipping (if applicable), and labor (If applicable also) More than likely an LS swap, B16 swap, or built and/or boosted D16, is what $2500 will get into your Sol. |
Re: $2500 what engine to get? (JV)
im planning to save for the endyn supercharger, so what do you think would be best?
what about a stock b16, with a rebuild? |
| All times are GMT -8. The time now is 03:32 PM. |
