wheel bearings
wheel bearings
I recently hit a curb with my front passenger tire. it slightly bent the rim. the front passenger tire is shaky and progressively getting worse. Is this just the rim or will i need to replace the bearing as well?
Re: wheel bearings
Lower control arm and lower ball joint may be damaged as well if the wheel bearing is damaged, and you may need a camber kit to keep tires properly aligned even after performing these repairs. Take the car for an alignment and have them give you an measurement before and after the task; assuming your LCA and wheel bearing doesn't show physical signs of damage . You can check if the wheel bearing is in sustainable condition by jacking the car up seeing if the tire/wheel wobbles; there are youtube videos on this.
