Suspension & Brakes Theory, alignment, spring rates....
what is the best suspension set up
Old 03-15-2010, 06:16 PM
ej193's Avatar
Default what is the best suspension set up
ok im looking to get some coilovers for my civic hatch i want some good track and street use plese let me get some feed back tnx
i narrowed it down to 3
1. buddy club racing spec dampner
2.tein flex dampner
3.apex i si dampners
so give me some advice please thnx
Old 03-15-2010, 06:26 PM
JonySoprano's Avatar
Default Re: what is the best suspention set up
Maybe it's not be best setup, but it's a good one for daily/track use.
koni/ground control coil-over
Old 03-15-2010, 06:28 PM
MiG-21 superfan
builthatch's Avatar
^ agreed. very robust and reliable setup.
Old 03-15-2010, 07:43 PM
ej193's Avatar
bump
Old 03-16-2010, 07:11 AM
ej193's Avatar
bump
Old 03-16-2010, 07:13 AM
kaiba's Avatar
Default Re: what is the best suspension set up
You heard it already and will most likely heard it more.
Koni yellow with Ground Control.
Old 03-16-2010, 07:49 AM
ej193's Avatar
are they really better then apex i
Old 03-16-2010, 07:54 AM
MiG-21 superfan
builthatch's Avatar
Originally Posted by ej193
are they really better than *insert full coilover name*
yeah...reason is-
koni makes, arguably, the best mass market damper available.
combine that with arguably the best springs in the world, Eibach, and put them on a well-engineered sleeve for height adjustability and you have, in total, a wonderful high quality option for street and track abuse.
all of those setups you listed have compromises. it might be the R&D behind them, it might be the spring material...it might be the tuning between the damper and the spring. alot of people use them, and they are popular, but when you break it down you'll find the overall package of the koni setup to be ideal, especially if you are using it for more than a particular look.
my 2 cents...
Old 03-16-2010, 08:08 AM
ej193's Avatar
thnx
Old 03-16-2010, 02:44 PM
ej193's Avatar
bump
Old 03-16-2010, 06:26 PM
TRIAL USER
99em1si's Avatar
i know that narrowed it down to 3 but i just bought some Blox full competition coilovers from www.jhpusa.com for a good price. check it out
Old 03-17-2010, 03:45 PM
ej193's Avatar
bump
Old 03-17-2010, 06:23 PM
dandaman15's Avatar
No need to bump this anymore, your question is answered. Koni/GC is the most reliable, longest lasting, and relatively cheap option available.
Old 03-17-2010, 06:34 PM
zserious's Avatar
Konis/Ground control.
Old 03-17-2010, 06:36 PM
MiG-21 superfan
builthatch's Avatar
haha
Old 03-17-2010, 08:40 PM
95skunkedgsr's Avatar
can lead the horse to water but cant make him drink it im riding on skunk pro c's but my next setup will be koni/ground control
Old 03-17-2010, 09:57 PM
STOCK_SOHC_DX's Avatar
2.tein flex dampner
Having driven/owned 2 out of the 3 I will tell you that the Flex's will be the best out of this group. The Apexi S1 is fairly newer but knowing how JDM race valving feels like I will tell you that those shocks are most likely not good for anything but track. The Flex's are very streetable but for the price Koni/GC is just as good. If you must have full coilover system check these guys out http://www.amrengineering.com/ around that price (the 3 you have mentioned) quality is right there with Ohlins.
Old 03-20-2010, 08:02 PM
curtis_mk3's Avatar
i did the same good stuff
aemintgsr
30
10-27-2012 11:05 PM
Juiceman313
Suspension & Brakes
13
01-03-2012 09:16 PM
EG-SIXV-TEC
15
08-17-2009 03:38 PM
4twenty_CRX
13
06-14-2007 02:46 PM
Fourstroking
08-08-2001 01:57 PM
Quick Reply: what is the best suspension set up
