Skunk 2 Ball Joint Thread Pitch/Size needed! Castle Nut Size?
I want to replace the castle nut on my skunk 2 UCA's and need to know the thread pitch of the ball joint or the size castle nut to purchase. I've already tried using an OEM castle nut and it wont thread onto the skunk ball joint.
Maybe its an SAE size? All help is appreciated. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Skunk 2 Ball Joint Thread Pitch/Size needed! Castle Nut Size? (EnjoyTheRideDC2)
12 x 1.25 17mm
Re: Skunk 2 Ball Joint Thread Pitch/Size needed! Castle Nut Size? (dvp)
if this don't work just use a metrix thread pitch gauge and vernier to measure the dia https://honda-tech.com/forums/images/smilies/emthup.gif
give us a call and i can see if we could sell you some hope this helps (951) 808-9888
Re: (SKUNK2GABE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKUNK2GABE »</TD></TR><TR><TD CLASS="quote">give us a call and i can see if we could sell you some hope this helps (951) 808-9888</TD></TR></TABLE>
PERFECT! I'll be sure to call. I cant find that size castle nut anywhere! |
Re: (SKUNK2GABE)
Bringing this one back up because I am still wondering...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 »</TD></TR><TR><TD CLASS="quote">I want to replace the castle nut on my skunk 2 UCA's and need to know the thread pitch of the ball joint or the size castle nut to purchase. I've already tried using an OEM castle nut and it wont thread onto the skunk ball joint.
Maybe its an SAE size? All help is appreciated. </TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvp »</TD></TR><TR><TD CLASS="quote">12 x 1.25 17mm </TD></TR></TABLE> If that were the case, the OEM Castle nut would work, which it does not... Thread pitch, not right. Wrench size to remove the castle nut is 17mm... <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKUNK2GABE »</TD></TR><TR><TD CLASS="quote">give us a call and i can see if we could sell you some hope this helps (951) 808-9888</TD></TR></TABLE> SO far, no luck there.. Any other help? |
Re: (EnjoyTheRideDC2)
My Skunk 2 UCA's were threaded the same as the stock ones. It would be silly if thery made them different. Try contacting Skunk directly.
Re: (dvp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvp »</TD></TR><TR><TD CLASS="quote">My Skunk 2 UCA's were threaded the same as the stock ones. It would be silly if thery made them different. Try contacting Skunk directly.</TD></TR></TABLE>
Do you have the original UCA's or the Revised Pro UCA's? |
ive had trouble getting the stockers back on the stock arms before new ones go on a lot easier this might be the problem
The old ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 »</TD></TR><TR><TD CLASS="quote">Do you have the original UCA's or the Revised Pro UCA's?</TD></TR></TABLE> |
Re: (vtecmissle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecmissle »</TD></TR><TR><TD CLASS="quote">ive had trouble getting the stockers back on the stock arms before new ones go on a lot easier this might be the problem</TD></TR></TABLE>
I guess i'll try a new one out and see what happens. Thanks for the reply. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvp »</TD></TR><TR><TD CLASS="quote">The old ones.</TD></TR></TABLE> Oh, maybe the ball joint has changed. I'm referring to the revised pro set, the one with the plate on top of the ball joint. |
