Suspension & Brakes Theory, alignment, spring rates....
Anyone here swap out the steering rack on an eg
Old 12-18-2015, 09:17 AM
SpeedRacerEX-R's Avatar
Default Anyone here swap out the steering rack on an eg
I'm going from eg steering rack to integra steering rack. Do I have to change the reservoir or are they the same size? Also, I've noticed that the boot between the rack and the firewall is not fitting the integra rack. Do I have to order that boot as well?
Old 01-09-2016, 07:43 AM
Default Re: Anyone here swap out the steering rack on an eg
Okay, the boot has been discontinued. Time for Year One to come out with a catalog for a Civic.
Old 01-11-2016, 07:06 AM
mikeg'seg's Avatar
you may have to got to the junk yard and pull off the best looking boot.
Old 01-15-2016, 08:37 AM
I bolted it up with the civic boot and it seems okay. Now the new issue is that the civic p/s has 3 lines where the integra p/s only has 2. So I'm going to need an integra p/s reservoir and lines. Yay!
Old 06-06-2016, 03:39 PM
Follow up. You will also need the joint that goes between the integra rack and civic steering column.
AMGkobez
05-10-2009 05:10 PM
SLIPSTICK TIPPIN
08-01-2005 01:38 PM
92sleepR
05-13-2002 08:07 PM
Quick Reply: Anyone here swap out the steering rack on an eg
