Rear Trailing Arm Removal
Can anyone forward me any writeups on how to remove the brake line and e-brake cable from my rear brake assembly. I'm trying to take off my rear trailing arm to replace the bushing (No I dont have that sick tool everyone uses) and don't know how to get the brake lines off.
Thanks |
Re: Rear Trailing Arm Removal
there is this tools that removes the bushing without removing the trailing arm it runs about $135 to $150 and it will take you 15min on each side.
Originally Posted by elnavajas
(Post 42694552)
Cant you just rent the tool?
A hammer will work also. |
Remove the retaining pin from the ebrake cable and you'll easily remove the cable from the trailing arm. Everything is easy as long as nothing is seized.
