Pros and Cons to Lowering Springs, Coilover Sleeves, and Full Coilover Systems
#26
Re: Pros and Cons to Lowering Springs, Coilover Sleeves, and Full Coilover Systems
Oh sorry. Got too engrossed in the details that I forgot to answer your question.
I'm not sure that they sell them in Canada but if they do, the ST Suspension ST X coil overs. They come with soft springs and are amazingly comfortable on the street. The quality of the springs and casings have gone way up since KW bought them and they work well as a package. They don't work well on the track due to the soft springs and crazy high low speed damping. But if you want a comfortable ride, good looks, and rust resistance that's where I'd go.
If not that then B_Serious' suggestion of entry level Teins is also good. I would look at one of the "Z" kits with the sealed dampers first because they come in cheaper and have identical damping to the street advance. Not quite as comfortable but like he said they are more durable and they seem to do a little better in a track environment.
#27
For reference though, the springs off of an ST X coilover for an FA / FG Civic dyno around 240 lb-f/in front, 300 lb-f/in rear. The Tein Street Basis Z for the same car comes with springs that are something like 336 lb-f/in / 448 lb-f/in. The black springs that come with most Tein coilovers tend to have slightly lower than the rates than they advertise, but even if you lopped off a few lb-f/in you're talking about a 25-30% difference in spring rate.
25-30% is huge. In the context of track / auto-x use, I can tell you that when we change springs in our race cars, we make changes in 10% intervals. That's about what it takes for a moderately experienced driver to be able to tell the difference in a blind test. A change of 25-30% usually involves revalving the dampers.
Based on similar stories I'm hearing from the late model BMW crowd I'd expect a 20-30% lower rate compared to other popular coilover applications in the same price range.
#28
Cool Cool Island Breezes. BOY-EE
I mean I obviously think they're much better quality than anything made by k sport, Megan, bc whatever other chinese coilover. It's just my personal opinion, I don't need coilovers for the street. I'd rather have something dual purpose even if based on older proven tech. I don't need motons or penskes either.
Dual purpose coilovers that ride well when taken out of the box don't exist for under $1500ish.
Off the shelf Koni with high enough spring rates to work on a track won't ride all that brilliantly on the road.
So here's a question - Why do you think the Konis are better shocks? They are the more expensive damper, yes. There are also a lot of used ones out there which is an attractive proposition for someone who wants to rebuild a set..
I am really curious because I've gone through and done a ton of shock dyno testing across popular brands, sat in a lot of cars with aftermarket dampers, and have some experience opening them up as well. Aside from brand affinity I don't see any reason why they would be a better shock. And they have lots of downsides (some of which are pretty hilariously bad, depending on the application).
Most twin tubes are lazy. Konis just have a better damping curve.
Didn't like my ST-X for my TSX at all. The ride was choppy and the stupid plastic spring collar for the front shock degraded within 6 months and the springs started making tons of noise.
Plus, the STX is zinc plated. They put salt on the roads in Canada. Bad combination.
Teins are less likely to leak or wear out than anything by KW, in my experience.
#29
Teins (except for the new Z line) are made in Japan.
Tein's twin tube shocks are all lazy in the slow speed region of the damping. So you have to crank them up to make them not floaty. So you only have a narrow band of settings that work for comfort while also properly damping bumps.
ST-X don't ride as well as the street advance in my own experience. Lots of complaints on the internet about KW's ride quality and overall quality. I liked my KW's for my S2000 and they lasted for me. For other people, they leaked and required warranty work often.
#30
TTein's twin tube shocks are all lazy in the slow speed region of the damping. So you have to crank them up to make them not floaty. So you only have a narrow band of settings that work for comfort while also properly damping bumps.
That said, I live in an area where street salt, snow, and rust is a problem and the newer STs seem to hold up just fine in this weather. The thread on the adjusters can stick but the bodies don't corrode as badly as other dampers. My recommendation for these (and pretty much any other coilover sleeves) is to spray them down with Boeshield T-9 every time the wheels are off. That keeps them from rusting and sticking.
Ride wise STX is valved the same way as KW V1s for most applications. I personally don't love the feeling of the shocks overpowering the springs on a street car, but a lot of people find that comfortable. Plus they come with softer springs and come in at a very competitive price. That's why I'd lean that way for someone who is primarily interested in street use.
#31
So at the end of the day, would you recommend Koni over Tein? I'm personally leaning away from Tein's complete system so that I can have the ability to change the spring out for a stiffer spring for track weekend and then back to a softer one for street use when I start doing some auto x, since I wont being going to the track every single weekend.
Soft street springs for comfort. And a bunch of different rates for track/autocross use.
Best to get alignments every time And make sure in your ability to do basic math and measurements.
#32
General question here, after reading another post. Does wheel size have any effect on lowering? I currently have 17" rims when stock is 14" but my low profile tires make the wheels the exact same size as stock (same circumference and width). I also do use winter tires which use the original 14" steelies, but again, the winters and the summers are the same size overall.
#33
How much lower are you actually looking to go? If you lower your car 2+ inches on stock shocks, you're going to tear the tires/wheel wells up. If you save up for a coil over setup, you will A) have a stiffer spring rate/strut combo that will avoid rubbing & bottoming out, and B) you will have the ability to raise or lower your car after you test the results in ride quality, tire contact, etc...
hugebob
05-21-2012 09:10 PM
