Suspension & Brakes Theory, alignment, spring rates....
HelpPlease.Question
Old 03-21-2012, 01:26 PM
Masturchiefs's Avatar
Default HelpPlease.Question
Hi,
(CIVIC EG HB 92-95)
I am new to the website, and going to start of with a question about coilovers.first i want to say also that if you get CXRACING coilovers for an EG teggy whateve, they don't go that low!
I just recently maybe a few months ago bought some CXracing coilovers and when i installed them i lowered them to the MAX and they only dropped 3" or something i have 195/75/15's and my fender is only at the top over my tire covering like a few cms of my tire tread.
i wanna be dumped
the coilovers are the type that you screw the mounts to adjust the height.
so i figured id cut of like 3" of the threaded cylinder part. but im not sure if the damper is inside this part does anybody know??? does the damper go from top to bottom???
V V V V V
Old 03-21-2012, 01:47 PM
been there done that
doood's Avatar
Default Re: HelpPlease.Question
DO NOT cut your shocks
if you wanna go lower either remove a perch or get a shorter spring
Old 03-21-2012, 01:52 PM
i dont think you read my post clearly
im not cutting the springs,
i wondering if its ok to cut the THREADED CYLINDER PART???
in picture1 where i drew a line across,
my kind of coilovers are the ones you adjust by screwing the mount
Old 03-21-2012, 02:27 PM
doood's Avatar
i read your post correctly, you didnt read mine. i said dont cut the shock, not the spring.
Old 03-21-2012, 03:41 PM
oh see, iddnt know that that part is shocks....i def wont cut it,
crap..
i guess i cant be lower then.
Old 03-21-2012, 04:01 PM
TunerN00b's Avatar
Of course you can get the car lower.
Just move the spring perch lower on the shock body.
However, your original post states that you want to be dumped, yet you're already dumped since you claim to be tucking tire. So, please, don't complain that they don't go low, you're already way too low for the car to be practical.
Unless the claim of running a 195/75-15 tire size is actually correct, in which case, you're an idiot for running a 26.5" diameter tire on a car intended for < 23" tires, and of course you can't get the car very low.
Old 03-21-2012, 05:30 PM
no my tire is NOT covered by the fender. well anyways i fixed, i asked for help and i get bitched at by you so **** you! TunerN00b :thumb down:: thumbdown::thumbd own::t humbdown:
and if my question makes you upset go post insomone elses thread bitch
not using this forum website anymore
Old 03-21-2012, 05:52 PM
TunerN00b's Avatar
Hum, "covering like a few cms" (whatever those are) sure sounds "covered".
Actually, you asked for help and got an answer.
Other than you, no one is upset. I'm laughing over here. It isn't every day that someone actually asks if it's ok to cut a shock body...
Old 03-21-2012, 06:14 PM
doood's Avatar
thank the lord
if you decide to come back and read more comments, i already told you what you have to do to go lower. dumbass.
Pat92904
Suspension & Brakes
11
10-28-2016 11:50 AM
OregonDucks
Suspension & Brakes
26
09-27-2015 08:18 AM
benchmade
Suspension & Brakes
07-08-2007 01:10 PM
slow_ls
06-30-2007 10:48 PM
fluke83
07-19-2004 02:51 PM
Quick Reply: HelpPlease.Question
