ITR Mini front brake upgrade. Look here for an update!
#76
imho, your pads are the problem...
No cooling ducts. Even worse, just started running a splitter where there was none before. And fwiw, my laps times are very competitive, I am hammer down out there. I really think your pads are the problem. There are only about four Honda's in my Group C class HC, and two of us are now running my setup with consistent results.
Look, maybe just call the guy who assembles the pads, Tim at Raybestos (they are custom made) and tell him how screwed up things are for you. See if he has any thoughts. Can't hurt. (RC503 in ST43 compound),at 949-548-4470.
#77
Re: ITR Mini front brake upgrade. Look here for an update!
Do you have any form of brake cooling installed?
I'm driving an integra, similar specs to yours but I'm using Dunlop ZII's and no brake cooling. I am also using rotors from autozone, last track day I went through 2 sets. I am going to install cooling ducts and see if it helps to increase the rotor life.
I was running cooling ducts on my car (2000 Civic hatch setup for Honda Challenge H2) for a while with the brakes being ITR/Honda V6 calipers with 11" Fastbrake two piece rotors (1" thick), and I had an issue with a bad shimmy/vibration intermittently during hard braking. One long time racer mentioned that by cooling ducts might be causing the vibration issue, as they were directly most of the air against the inside face of the rotor instead of going to the center of the rotor. For my last event, I switched to redrilled VTEC rotors (23mm thick) and removed the cooling ducts, and the brakes worked great without any vibration. The bottom line I'm getting at, is that from what I've seen/been told, that the brake cooling ducts are tough to run a FWD car (to keep them away from everything like the tire plus axle). The best thing would probably be to have the end of the cooling hose connected to the hub etc. so the air goes directly to the inside of the rotor. The thread https://honda-tech.com/road-racing-a...honda-3227099/ has a picture of that person's cooling ducts and bracket on post 14. When I removed my cooling ducts, I had left my steel attachment brackets connected at the lower shock bolt, and with the car on jackstands, there was plenty of clearance from the wheel rim to the steel brackets, but when I unloaded the car at the track, I was getting a bad metal scraping sound at full lock in the paddock. I found that with the car on jackstands, there was plenty of clearance from the steel brackets to the wheel rim inner face, but when I lowered the car back to the ground, then there wasn't nearly as much clearance. My car has spherical bearings, so not sure if a standard bushing at the lower shock would show the same change.
I was looking at a nice Mazda RX8 race car a few weekends ago, and it was interesting to see how he had to snake the cooling hose through the suspension and steering arm, but he had a backing plate where he could attach the end of the cooling hose to. He didn't have to worry about clearing a front axle or CV joint, but it was still interesting to see how he snaked the cooling hose.
If you do decide to install cooling ducts, then first read https://honda-tech.com/road-racing-a...cting-3249439/ as post 4 has some nice pictures including a bracket to keep the cooling duct air directed to the center of the rotor, and pictures of my setup in post 8, plus links to other threads on cooling ducts.
- Jim
#78
So I finally got around to doing this and aside from some heat shield interference and seized bolts everything went well.
I got all my parts from Rock Auto for about $300 including new brake lines with it. I can definitely feel an improvement but I think one of the old pistons were seized anyway. Plenty of room in 16" wheels and look nice as well.
I went with the TSX 787 pads like posted above and drilled rotors from the Mini. Made it home after finishing everything so I think it was a success.
#79
Wow! That sucks and is freaking awful. I have not had the new pad profile on long enough to say anything about longer rotor life. I do not have rotor issues like you describe using ST43's. But dk if our situations are similar or not. My application is on a '99 Civic Si at 2,325lbs race weight, me in it.. The car lives only on the track and is unreg'ed and trailered. I run NT01 and Hankook c51 tires. I have had disastrous results with a set of Hawk pads that were spares (pulled and boxed) that came with my race car. They were destructive on the rotors and the transfer layer seemed to wear off in certain parts of the rotor. I don't know one person at Northern California NASA Group C race that uses Hawk pads. I am sure they're out there, I just don't know who it is. May I suggest you consider Raybestos ST43's?
Here's what goes on with me, sorry to ramble.
The Autozone Duralast rotors hold up for about ~2/3rd's of the wear of a set of ST43's. There is a point where I see micro cracks appearing uniformly throughout the rotor. I normally return those rotors after that weekend and bed a new set of virgin rotors with the fully bedded ST43's. I cycle new rotors on seasoned pads, new pads on seasoned rotors. Re-read that last sentence, it is key. I do whatever I can to never attempt to bed both at the same time. Too easy for me to screw up the bedding process when all is new, something goes FUBAR during the heat cycle or the transfer is wrong between them. Whatever, it shouldn't be this picky, but I accept what works and leave it at that. Always bed new to old.
When I see the micro cracks, I know its borrowed time. I won't run a race on them, but might do practice and qual. Or maybe a fun day, lapping in non-competition or something. I might also bed new pads on micro cracked rotors. But those rotors get returned for new ones shortly. Always attempting to go new and old, making the virgin rotors get hit by seasoned, cycled, ST43's. Pull the rotors as soon as I know they're good and I feel the bedding is in. Those get pulled and are the new back ups. Do the same with pads. Always have bedded set waiting. I could not run just one pair of pads and rotors. I have a full back up set of pads/rotors.
But...you just point out something I never really though. The dtc70 could be the cause of my craking rotor... This year I start the season with dtc60 and didn t have too much crack until I switch back to dtc70 on my last 2 track days. Now my rotor are full of cracks. I must add that this year I went with the euro big brake conversion option, the MG Rover 25 mm thick rotor that I have import from UK trying to solve the cracking issue. A good friend of mine run the same set up but start having cracks way before than me. And I think he s running dtc70 since day one this season...
As for the mini set up option I notice that the piston is push further out as the pads are wearing and it cause the rubber that protect it to be carbonize way ealier... This could cause damage to the inner seal and cause premature faillure of the caliper... My 2 cents... Probably not an issue for street app but for track...
#80
@Maxo, yeah, pads are the thing that bring the heat. Rotors, pads, tires are all consumables for race cars. I was burning through Carbotech HP10's at $225 a pop. The rotors were outlasting them. My experience is that the St43's are predictable pads and take out the rotors, not the other way around. I'm satisfied with that trade off. I wish there was a silver bullet rotor we could run.
#81
Idk y people are worried about mixing parts up, its not like you have a honda turbo kit on your car or have honda made brake pads on your car and even if you did buy the from honda, they have other companies build these parts for them.
#82
No.worries for me, I even run a gm truck rad on my K20! But you are right, people thinks that honda built the whole car, but truth is that the re a bunch of compagny that built parts for them... Takata, exedy, gates, nissins just to name a few...
#83
...Many of which are vendors owned partly or wholly by Honda and are making parts strictly to their specs, but yeah you're sort of right. It wouldn't make sense for them to have a radiator hose factory when there's already one dedicated to making them.
#84
DIY: The No BS Bolt on Big brakes for RS/GS/LS/GSR - Team Integra Forums - Team Integra
here is another write up for this, he says he read it on HT not sure if there was an original link but anyways more questions and answers in that bigger TI thread- 55 pages of shared advice and rim fitments
#85
Pads loose?
I just put together this kit from rock auto.
I ordered the Cardone Ultra ITR front calipers and TSX EBC green stuff pads, however dropping the pads into the calipers with the included shims there's about a millimeter of play still. Checked all four pads in both calipers all are about the same.
No surprise EBC greenstuff rear ITR pads fit the rear calipers completely snug as I'd expect.
Has anyone else seen this?
Could the retention/alignment tabs on the TSX pads be shorter than ITR, or the incorrect bracket have been provided, or more likely did I screw something up. Seems enough people are running this setup. Just worried about the pads banging around as they make contact.
Any help/thoughts are appreciated.
Thanks
Thanks
#86
Nice thread, I'll tell you what setup do i have in my hatch.
It's a '92 eg6 EDM, the one that came with the b16 stock and ABS, 260mm front 240 rear.
Itr Front calipers, Itr pads, and EBC rotors for MG ZR 4x100 282mm. Totally Plug & play, if you use ITR caliper holder, with CRV ones just need to use a 1mm washer.
Several tracks days and DD, no issues at all.
On the rear I have 260mm front a euro Ep2 prerestyling, same as the ep3 rotors, but 4x100. Just took the ep2 calipers and crossed them, Right one to the left side, left one to the right. You can use 'em without doing this but at least in my hatch brake and ebrake lines came this way, and didn't want to change that. (You have to bleed the rear brakes with the caliper out of the arm, because the bleeder is in the down side, but it's easy)
Have some friends with the mini rotor conversion, but pads issues as well.
All with HEL ss braided brake lines.
#87
Thanks
Thanks
#88
#89
Re: Pads loose?
So have to say I don't recommend the Cardone ultra reman. calipers. The "ultra" part is a powder coat which is nice for rust resistance but is applied in/on all parts and threads so all bolts and clearances are affected. They did bother to clear the brake line threads but not the line capture tabs or any of the mount holes/threads so had to back the first one off and clean the tabs and other parts off before it would go into place gently. One piston had a pretty good knick on surface and from some of the comments I'm seeing I think they used a different caliper bracket. I ended up making up some c shaped shims for pad tabs to fill the extra mm in pad play, means I'll need to watch wear closely before one ends up on the rotor and to make sure there aren't issues I missed with alignment on rotors. In the end the pads still sit just inside the rotor edge where they should and brackets clear my 15x6 45et 15 spoke Civic Si? wheels.
Fronts by themselves seem to be a nice improvement over original '97 LS setup. Only use for DD in SoCal so all beyond the point and just for fun/my own aesthetic.
Didn't get the rear on since parking brake bracket didn't match up with 97 ITR calipers, so will order those maybe from Park Acura, and maybe do entire cable set since my pass. side seems more stretched out from DR side anyway.
Have an ASR brace and H&R OE sport springs to get on as well so will just have to find another day to pull things apart again.
Many thanks to the HT posters dropping knowledge and making these projects so approachable to us arm chair mechanics!
#90
O
O
#91
As an 4th gen Prelude guy, I don't understand why u can't just get ITR rotors? Is it the bolt pattern holding u up?
I ask out of curiosity but also because I was able to do the Legend GS 2-piston brakes complete with Legend rotors because I did a 5 lug swap for a couple hundred bucks. Is this the alternative for u 4x100 guys?
#92
I did the brake upgrade using the Rock Auto powdercoated Calipers and Mini Rotors with TSX pads.
I feel like the fitment is not quite right, as if something is rubbing whether it be a pad or a bracket to the rotor. I have seen in a few threads people machining the bracket down about 3mm.
Has anyone else run into this issue? or have any thoughts on this.
#93
With powder coating a substantial layer is added to the coated parts, this can affect fitment if mating surfaces aren't cleaned of the coating. If the caliper\bracket is rubbing\scraping on something you should be able to see an area where the power coat has been scraped away. Also check the pad shims. If they don't sit perfectly on the bracket they can stick out and scrape on rims or in my case they rubbed the balancing weights on one of my wheels. This was easy to correct by trimming the edge of the shim enough so it allowed clearance.
I did have issues with the A1 Cardone ultra premium calipers (Grey\Silver powder coated, parts 19P1460 and 19P1461) from Rock Auto. I'm now certain they came with the incorrect bracket but my issue was with the tab size which held the pads. I was able to shim, still trying to find the correct pads for the brackets.
Rock Auto also still lists the Raybestos rear calipers (parts FRC11159 and FRC11160) as an application for '94+ Integra Type R even after I had to return my order and requested they correct the application listing. FYI these won't work on anything older than a '98 since the parking brake arm was changed in '98. The calipers had at one point included the parking brake arm so were a compatible application, however, Raybestos no longer includes the required arm. Sadly these $10 arms are also discontinued Acura parts and not available any where I tried to source. The '94-'97 arms cannot be mated to the '98+ calipers.
#97
#98
Mg Rover ZR 160... It s a British car... I ve found this set up trying to find 25mm rotor and end up on an Europeen forum where guys runs this has an upgrade...
It works great! I m on the 2nd set and the rotor last the full seasons last summer. I usually do about 50-60 hours of track every years... And my home track is known to be tough on brake!
#99
RACE USE: Report.....
I have recently converted from ITR pads to the no overhang TSX pad (profile 787). The entire system is better as a result. The "over bite" problem, as I call it, it gone.
My car is essentially a fully gutted H1-H2 race car. I drive the $hit out of this thing. Group C Race with NASA and some other clubs. Sonoma Raceway, Laguna Seca and (imho) the big destroyer of brakes, Thunderhill Raceway. Changing to the TSX pads made a significant improvement. I have the 7/8 master and I run a brake bias valve set for full rear. The brake peddle modulation is better with TSX pads, the rotors run cooler, there is more braking force. In essence, everything I can think of got better by simply switching pads.
The ITR overbite, imho, created a hotter rotor. The pad was making contact completely out to the edge and actually, in an odd way, wrapping around the outside edge. imho, that aspect of it may contribute to a hotter rotor the accompanying system stress side effects. The Raybestos ST43 pads actually never really fade, they just heat and beat the **** out of everything near them and put the stress on them.
Enter the TSX pads. No "over-bite". Perfectly matched contact to the MiniCooper rotor. The outside edge of the rotor is now able to offload heat better. The inside edge where the new contact is being made seems better able to handle things.
What all this means to me during my practice/qualifying/race sessions is an improved ability to predictably, consistently, bring the car to threshold braking, when needed/necessary, time after time, deep and with less heat in the system. I like all of that.
I also want to mention there there were absolutely no side effects, such as scraping, squealing or anything else. I am using all the springs and clips that I have always used. I have no friggin idea what some of you experienced, thankfully I have no issues what so ever.
To do this change over of pads, I just swapped pads and went with new rotors. I attempted to run the old rotors, but the wear pattern was too different to what the new pads wanted. So I returned the rotors and got free replacements. I run Autozone $35 blanks with their no questions asked two year return policy that I use a couple of times a year. Sometimes I spray them with a high temp paint to protect from rust. I have used these in race applications over the past ~four years. imho, these are just fine for everyday use as they are just fine for race. I found they last nearly as long a cyro treated expensive *** rotors I tried one time. Which cracked all the way through on the outside edge. So f $119 rotors.
I can only heap praise on Honda TypeR, the OP, for bringing this info to the community. Thank you! .
We'd like to learn more about your prop valve. When you say "brake bias valve set for full rear" could you please elaborate on your settings?
