Suspension & Brakes Theory, alignment, spring rates....
ITR Mini front brake upgrade. Look here for an update!
Old 05-07-2015, 04:10 AM
  #26
Meoshe's Avatar
Default Re: ITR Mini front brake upgrade. Look here for an update!
Do you get any noticable chatter/squealing with out the springs in there?
Old 05-07-2015, 05:25 AM
  #27
Honda Type R's Avatar
No. The brakes seem to function fine. I'm running GSR rear calipers over an EP3 rear rotor with EP3 caliper brackets and GSR pads on the back and on that setup I had the same problem with the springs. I've been on that setup for 6 months without the springs and not a bit of noise. I only took it down the street without the springs on the front and I didn't hear anything. I'm going out to The Tail of The Dragon this weekend, I'll post back if there are any issues
Old 05-07-2015, 06:01 AM
  #28
Meoshe's Avatar
Ok, thanks for your investigatory work. It is much appreciated.
Old 05-09-2015, 03:42 PM
  #29
Chefskinny's Avatar
What needs to be done to run the mini rotors and ITR pads?
I already have the rotors and pads
Old 05-09-2015, 05:49 PM
  #30
Meoshe's Avatar
You need the ITR calipers, its all explained in the first post. The tsx pads are the ones that have no rotor overhang.
Old 06-25-2015, 09:27 AM
  #31
Gidster's Avatar
Icon2 Re: ITR Mini front brake upgrade. Look here for an update!
Excuse me for looking like a noob here, but can I do this set up on a DA? I have a 1990 Acura Integra LS B18a1 motor, would i be able to do this on my car?
Old 06-25-2015, 10:11 AM
  #32
ls joker's Avatar
yes
Old 06-29-2015, 11:40 AM
  #33
Swaggylicious
$amGD3's Avatar
Is my list right ??
CENTRIC Part # 14140050 Reman; Premium Semi-Loaded Caliper One of our most popular parts
Front Left; Type R
$43.79
CENTRIC Part # 14140049 Reman; Premium Semi-Loaded Caliper One of our most popular parts
Front Right; Type R
$43.79
AKEBONO Part # ACT503 {Click Info Link for Alternate/OEM Part Numbers} Front; Type R; Akebono is the OE Manufacturer; OE Pad Material is Ceramic
Part Image
$41.79
PRONTO Part # BR900670 {#900670} Front; w/ 280mm Dia. Rotor; Vented
Part ImageNext Image
$15.33
Old 06-29-2015, 12:01 PM
  #34
Originally Posted by $amGD3
Is my list right ??
Front Left; Type R
$43.79
Front Right; Type R
$43.79
Part Image
$41.79
$15.33
Get pads for an 04 TSX instead of the ITR. That's what this whole thread is about
Old 06-29-2015, 12:07 PM
  #35
Swaggylicious
$amGD3's Avatar
Originally Posted by Honda Type R
Get pads for an 04 TSX instead of the ITR. That's what this whole thead is about
Ok cool, so this whole thing is about <$200
I wonder how noticeable of an upgrade it is over EM1 brakes
Old 06-29-2015, 12:56 PM
  #36
Couldn't tell you. I've never had EM1 or Integra brakes with good pads
Old 06-29-2015, 05:53 PM
  #37
Meoshe's Avatar
It is quite noticeable. Much more grab with less pedal effort and lock up happens a lot earlier so modulation is key. It just a matter of getting used to it, I can easily heel toe even tho the pedal is slightly lower since I didnt change the MC.
On a side note about the centric calipers... either paint them before you install them or get the powder coated powerstops because they will surface rust quickly.
Old 06-29-2015, 06:58 PM
  #38
Skip01's Avatar
Love stuff like this. Awesome info and digging out something that works better then the standard
Old 06-30-2015, 10:45 AM
  #39
I like to party
2LEM1's Avatar
The calipers alone are $95 each after the core charge. Hopefully you aren't buying the cheapest piece of **** rotors and pads you can find.
For good TSX pads you're looking at over $100. Why even do a 'brake upgrade' if you're going to use ****.
Old 07-09-2015, 09:50 AM
  #40
Amerika's Avatar
You can do this for the front and back correct?
Old 07-10-2015, 07:46 AM
  #41
SCoupe 5sp's Avatar
The pad number for the 2004 TSX pads discussed here are 787. I just ordered a set of Raybestos RC787 in the ST43 compound for my 00 Si track car from Porterfield
Really looking forward to seeing how this corrects what I thought of as the 'over bite" problem using the 503 profile pads. I have used an angle grinder to periodically bevel the 503 pads to avoid the edge overhang. It bugged me to see that part not making any contact and being completely wasted. I Curious to find out if this improves things.
Old 07-10-2015, 02:37 PM
  #42
m4xwellmurd3r's Avatar
Default ITR Mini front brake upgrade. Look here for an update!
For the back you need 2005(?) Civic SI rear rotors and itr rear calipers. Iirc RSX calipers work but must be flipped left to right so they need to be bled before final installation
Old 07-13-2015, 06:33 PM
  #43
Jundersco's Avatar
Sorry if this is a dumb question as I haven't seen it mentioned anywhere.
For the ITR calipers, would it matter what year I select for them? I have a 96 LS but the first year I see ITR calipers is 97. I know they're basically the same, but wouldn't want to get the wrong thing on accident.
Old 07-13-2015, 06:51 PM
  #44
bspeed's Avatar
rears you only need the rsx/ep3 back bracket, re-use your existing rear caliper and you don't have to flip.
Old 07-17-2015, 04:09 AM
  #45
Swaggylicious
$amGD3's Avatar
Is my list right ??
Front Left; Type R
$43.79
Front Right; Type R
$43.79
Part Image
$41.79
$15.33
Old 07-17-2015, 09:13 AM
  #46
SCoupe 5sp's Avatar
. Hopefully you aren't buying the cheapest piece of **** rotors and pads you can find.Why even do a 'brake upgrade' if you're going to use ****.
If you have some info from personal use, please name the specific piece of **** and how and under what circumstances they failed so none of us buy them.
Anyone interested in saving some money on your rotors, this is for you. I can highly recommend the $39 each Autozone Duralast Mini Cooper rotors. These blanks come with a 2 year, no questions asked return/replacement warranty.
Mine is a 1999 Honda Civic Si Race car that sees no street use whatsoever. I purchased high end, expensive, Centric Cryrogenic Treated Rotors last year (no warranty) to see if they offered an improvement. I found that they had no better service life. One developed a ~2 inch crack to the edge after ~ six weekends, (normally get six + from the Duralast).
Its not just me. I have three track buddies that drive the **** out of their BMW e36 in NASA Time Trails and / or Group C Race in the Nor Cal region. They began using Autozone Duralast blanks after seeing the use, the price, and the warranty replacement policy of the Autozone Duralast product.
I guarantee you that your street driven vehicle will be just fine with inexpensive Autozone rotors. Use the money to buy some great street use pads, such as EBC Yellow
Old 07-17-2015, 02:17 PM
  #47
lmfar427's Avatar
Agree on the point of buying power coated calipers.
ProParts USA Integra Brake Kit Upgrade - ProParts USA - Low Price Performance Aftermarket Car Accessories - Brakes | Shocks | Springs | Intakes and More!
I bought the Integra Big Brake Upgrade package with Stoptek Performance brake pads and now wish I had bought the low-dust versions.
I've put about 2,000 miles on them now and every week I wipe off a thick film of brake dust, making weekly wheel cleanup mandatory. The el cheapo pads I had on before the upgrade left no dust on the wheels at all, so the upgrade is a dusting disappointment.
The tapped holes in the calipers for the metric brake line bolts look like they were done with an oversize tap, cause the bolt screws in really loosely. I hope I never have to retighten the bolts cause they will likely strip out.
The rotors have no accommodation for the Integra locating screw, so the rotors hang loose or fall off if the caliper is removed.
In retrospect I should have bought power-coated calipers, cause the delivered finish on these calipers is bare metal, which rusts almost immediately if you get them wet.
I may also go to the EBC yellow pads for a change.
Old 07-17-2015, 09:16 PM
  #48
SCoupe 5sp's Avatar
Originally Posted by lmfar427
... every week I wipe off a thick film of brake dust, making weekly wheel cleanup mandatory. The el cheapo pads I had on before the upgrade left no dust on the wheels at all, so the upgrade is a dusting disappointment.
My experience with EBC Yellows is that they are not a low dust solution. Not awful, but far from no dust.
Old 07-19-2015, 09:33 AM
  #49
anthonyfa18's Avatar
This is some good information, I would like to know if this also applies to using 2 piston legend calipers with t23 itr calliper bracket ???
Old 07-19-2015, 01:43 PM
  #50
Meoshe's Avatar
It should work fine, I have one 23t and one 25t with my TypeR calipers. They were sent like that from centric.
Quick Reply: ITR Mini front brake upgrade. Look here for an update!
