Inner tie rods
I am in the process of replacing my 24 year old suspension parts in my integra. How can i tell if the inner tie rods are bad? I replaced the outer because its obvious. dont wanna throw money away. looking at pictures on rockauto i dont see how they can get worn out? looks like a ball with threads.
They wear out and will start to clunk
You should replace them even just because of age if they have no play Lift the one wheel and put your hands on 10 and 3 on the tire and move it side to side If its worn out You will feel play in the tire |
Re: Inner tie rods
Thanks dude. i'll just do them now. looking at them i would hate to do it when the motors in.
Re: Inner tie rods
If the accordian boots are torn and have been for a long time. Almost certainly the inner ball joint needs to be replaced.
Re: Inner tie rods
Originally Posted by 84Riceeater
(Post 49731138)
pull on the tie rod and feel for any loose play and while you're there grab the hub where the wheel studs stick out and see if you can wiggle those around. There should be no play, if there is then you need to replace your wheel bearing which would cost around $100, including the bearing if you take the knuckle and bearing to a shop with a press. |
Re: Inner tie rods
(Post 49731553)
It was harder getting the new steering rack boots/inner tie rod boots to sit on the groove properly and get the vacuum hose connected. I used zip ties to secure everything. |
Re: Inner tie rods
Originally Posted by Tyson
(Post 49731665)
Re: Inner tie rods
Originally Posted by InTheZoneAC
(Post 49731796)
They are super easy to replace even with everything in. Pop wheel off, loosen outer tie rod lock nut and start loosening the inner tie rod by spinning it.
It was harder getting the new steering rack boots/inner tie rod boots to sit on the groove properly and get the vacuum hose connected. I used zip ties to secure everything. Thanks! not sure what groove you speak of YET. but im sure I'll understand once I actually get down.but Just ordered inners! |
