how often do you guys check your rear endlinks and sway bar
ive broken 2 endlinks , and now today when i went to clean my undercarrage i noticed that the endlink going into the LCA was loose. this has never happened on the track , i broke 2 endlinks on the street , and this one loosened up on the street. so i wanted to see if anyone else had problems like these?
Re: how often do you guys check your rear endlinks and sway bar (Hella_JDM)
I'm using the suspension techniques speedtech kit shown below
http://figz.com/~brewer/dAng/Jeremy3.jpg my endlinks have never came lose, but the bolts that hold the bushing plates on at the end of the tie bar, seem to work lose a lot. I try to check them every time I wash my car, which is usually every Friday, I've recently put some removable lock tite on them, and it seem to have helped. |
Re: how often do you guys check your rear endlinks and sway bar (Jeremy D. Swain)
man the car looks real hot . its just kinda wierd how ive been having these endlink problems
My 99-00 si endlinks haven't seemed to come loose at all. But I only have a 13mm rear sway bar so that might be the reason.
Re: how often do you guys check your rear endlinks and sway bar (chowmien)
ya ive got a 23 rear lol.....
What rear sway setup are you using? Friend of mine was running the blox 19mm rear sway, with oem gsr endlinks, and his kept breaking.
He has since replaced them with Function7 endlinks and seems pretty happy with those. |
ive never herd of function 7 do you have a site? i have a jdm itr 23mm rear sway with si endlinks.
Here you go man, found this for you! Scroll down to the bottom, that should be all you need!
http://www.function-7.com/products.html |
awesome , now i just have to figure out how to order lol.
lol, I think you either have to either call or email.
Later Honda end-links are notoriously weak (ball-joint style). I think they make them like that because it's easy $$ when a customer get's his car serviced. Whenever a guy comes in to get an oil change, the tech will check the end-links and of course they are busted so they make an extra 25-50$ on top of the oil change.
Re: how often do you guys check your rear endlinks and sway bar (Jamez)
ya imma get the function7 units hopefully they will be nice.
hmm my SRR's are fine...the endlinks are rusty tho https://honda-tech.com/forums/images/smilies/emsad.gif....stupid EastCoast Winters https://honda-tech.com/forums/images...es/emdgust.gif
Re: how often do you guys check your rear endlinks and sway bar (ECAhatch)
I check them once a week on my progress bar.
Never found them loose, on or off track ! |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">awesome , now i just have to figure out how to order lol.</TD></TR></TABLE>
You can order any Function7 products through me! Just send me an IM, or email: Project.zum@gmail.com |
Re: how often do you guys check your rear endlinks and sway bar (DavidR)
i have an itr rear sway bar on my eg,no problems here.
however my buddy installed one on his integra and did not brace it behind the subframe and it ripped that shit right out,now he has four half dollar sized holes in his sub frame. |
Re: how often do you guys check your rear endlinks and sway bar (STN_Pat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STN_Pat »</TD></TR><TR><TD CLASS="quote">I check them once a week on my progress bar.
Never found them loose, on or off track !</TD></TR></TABLE> never checked mine i have a progress bar also i'll wait till pats come loose then i'll check mine https://honda-tech.com/forums/images...s/emsmilep.gif https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: how often do you guys check your rear endlinks and sway bar (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">never checked mine
i have a progress bar also i'll wait till pats come loose then i'll check mine https://honda-tech.com/forums/images...s/emsmilep.gif https://honda-tech.com/forums/images...s/emsmilep.gif</TD></TR></TABLE> It's been removed for the winter, hopefully you're fine by the time you read this https://honda-tech.com/forums/images...s/emsmileo.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeremy D. Swain »</TD></TR><TR><TD CLASS="quote"> http://figz.com/~brewer/dAng/Jeremy3.jpg </TD></TR></TABLE> http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg |
Re: (The_General)
Locktite #277 - stronger than cheap sockets https://honda-tech.com/forums/images/smilies/emthup.gif
