Function & Form Preload
i jus wanna assure this. whats the worst that can happen with my suspension when i release the preloads. i jus let off about 1/4 inch. im not gonna hurt my setup am i?????
Why would you change the preload? Just use the lower portion to adjust the ride height and adjust the dampening from there.
Re: Function & Form Preload (wesley_925)
the worst that could happen is youll bottom out the shock rod and damage the piston internally.
will it? i dunno. its all crap anyway. |
Re: Function & Form Preload (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote"> its all crap anyway.</TD></TR></TABLE>
Re: Function & Form Preload (mormonboy)
what makes them crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">the worst that could happen is youll bottom out the shock rod and damage the piston internally.
will it? i dunno. its all crap anyway.</TD></TR></TABLE> cant the same be said on other coilovers that are height adjusted by the preloads i.e. ground control, tein ss, etc.. |
Re: Function & Form Preload (firemanG)
absolutely.
so dont slam your suspension. |
| All times are GMT -8. The time now is 01:09 PM. |
