Energy susp. trailing arm bushing
#28
Re: Energy susp. trailing arm bushing
The last time I did it, I just used a torch, knife, and dremil to get the last little chunks of rubber out.
#29
The bushing did not burn easily, so torch helped. Get something that runs from a drill or airtool to brush/grind the remains out to clean. I used antiseize to lube, not the supplied lube based on some to the track guys experience. Ask the energysuspensionpart.com guy.
#30
had them in my old crx(already installed when i got car) didn't like how they limited the natural motion of the suspension and they always squeaked and ****
#31
Not had the squeeking with antiseize, yet. I am unable to tell if they limit motion. I would think that about 2200-2500 lbs of car would damage the bushings before stopping much car motion. Also probably depends on the whole package, lowering, stiffness and spring rates. How much motion is there?
#33
I would give it a shot, it's either going to work or it's not. lol
#35
I just used a torch and carb cleaner or brake cleaner, once the rubber gets hot enough all the way through it will continue to burn. I started it off by getting the rubber hot then putting a brake cleaner soaked rag on the underside and lit that. The flames traveled up and it burned.
#36
