DIY: No BS, direct bolt-on 11" Big Brake Kit for EF's!
#26
Steve at Heart
I recently installed a Raybestos 15/16 MC for a 91 EX on my 89 Si hatch and it fits without modification. Just FYI. I would use it over a prelude since the lines don't need bending. Good info on the BBK though OP.
#27
Re: DIY: No BS, direct bolt-on 11" Big Brake Kit for EF's!
95 Legend GS dual piston calipers
Mini cooper rotors
94-01 Integra Knuckles
Stock 2000 Si rims
#28
No wayyyy thats awesome! So any civic/teg with the 10" setup just needs itr or legend calipers and brakets with mini cooper 11" rotors and blam, big brake kit for like $150-200 or so and they even clear factory 15" wheels. This is def on my to do list.
#29
I'm not exactly sure what upgrading the rear brakes might do, from my little track experience the rear brakes hardly get used at all. My rear rotors have two track days on them and they still have the machining cross-hatching.... Wheels had barely any dust whereas the front wheels turned black from silver, and the rotors/pads look like they'd seen better days Lol. FWD's on the track really overuse the front wheels, they do practically ALL the braking.
Rear brakes do much more than anyone gives them credit for on a FWD Honda. they do about 20% of the work, and when you've only got a finite amount of grip, if your rear brakes aren't working then you're going to be braking earlier than the guy with 20% more brake force at his disposal.
In fact, it actually gets worse than that, because with 20% less brake force you can only brake at say .8g instead of 1g. This means less forward load transfer, which means less available grip before the tyres lock, so then you might see performance reduce to 70%.
Let's also not forget the rear suspension design on these cars which is designed to react brake torque, affecting toe angle and trail taking stability. There's also kinematic anti-lift, which stops the rear wheels decambering and losing grip.
If you think you back end feels light with updated brakes, it's because they're not doing enough, not because they're doing too much.
I would always upgrade the rear brakes. Front bias just make my EK4 worse.
#32
The centerbore on the mini rotor is ~64mm.
The civic rotor centerbore is ~61mm.
Which means the rotor is no longer hub-centric.
Although it will "work" I think really a hub ring should be used.
Does anyobody have a source for the proper size? I'm looking for some.
I know a few years ago BrakeExpert was making them but I don't know if he still is.
#33
In my research I found that MG ZS 180 rotors (available in Europe) are a better match than Mini Cooper's, in terms of center bore, stud diameter, overall diameter, retaining screw holes, etc. Those Rover/MG cars were Honda based.
I haven't been able to test them yet because I can't get the screws holding the old rotors out. I will let you know once that happens.
#34
Vented - Studs 4
Disc diameter 282.0mm
Disc thickness 25.0mm
Overall height 44.4mm
Centre diameter 64.1mm
Minimum thickness 23.0mm
The MG Zs is a V6 with a 2497ccm/177HP engine, fwiw.
#37
Sorry to bump an old thread but is this information completely accurate?
#38
The Mini rotors ARE hubcentric but they do slide forward and backward due to the larger stud holes than on our Hondas. I'm sure the brake disc slide back and forth during sustained breaking and ABS lock out.
For the track, unless the MG rotors work, it might be more reliable to use redrilled rotors rather than stock Mini ones.
#41
Has anyone confirmed that the MG rotors work?
#43
here is the way i have done on my 91 DX
from stock 9.3'' to 11''
i keep my oem 9.3 spindle.
Use a 2007 TSX front caliper .
vw corado G60 Disk brake.
All you need to do is use a special center ring because vw disk hole is bigger. Also you put the right caliper on the left and the left on on the right ( im sure you get it )
why did i do that versus EX / DA knuckle ?
first DA knuckle change your suspension geometry and is heavier than civic one.
EX knuckle is super hard yo find in canada
#45
These look like Hawk pads to me. Not sure which ones, as they are pretty hidden in the caliper in the picture.
If you use the 9.3" knuckle with a ring like this, make sure you keep close watch on your front bearings. I have seen a few fail with this kind of setup. They are a little weaker than the bearings from the 10.3" knuckles.
#46
ask your local machinist
pad is hp+
i also added SS brake line , RF800 brake fluid and 1'' type R brake booster and master.
Brake soo good but you need to have good tire .. i run NT01
nice to see some CCQ people here
pad is hp+
#48
#50
