DIY: Bleeding your brakes by yourself, it's not as hard as you think!
#26
Steve at Heart
Re: DIY: Bleeding your brakes by yourself, it's not as hard as you think!
Doesn't the power steering reservoirs usually come with a red cap? Don't think I've seen a master cylinder with one.
#30
This is what I am talking about. I am wondering if anyone has bled the high pressure fitting on the Modulator w/o the special tool "Bleeder T-Wrench"?
I was thinking that perhaps some shop rags around a 6 point socket on an extension and cracking the bleeder slowly would be adequate for dealing with the high pressure?
TIA,
TIA,
#31
Use a 9mm multihex 3/8 socket, fits perfect and gets the job done. I've bled about 5 different ABS systems using the 9mm socket with no issues now.
#33
Premium Member
Has anyone tried the Solo Blled from Earl's?
They look interesting, but I am reluctant to tamper with the factory design of brake systems...
Earl's Performance Solo-Bleed Brake Bleeders
https://www.summitracing.com/search/product-line/earls-performance-solo-bleed-brake-bleeders?autoview=SKU&sortby=Default&sortorder=Asc endingThey look interesting, but I am reluctant to tamper with the factory design of brake systems...
