CLICK HERE all of you curious about suspension setups and their costs/reliability.
#277
Re: CLICK HERE all of you curious about suspension setups and their costs/reliability
Illuminas would probably be your best bet on a DA chassis, unless you go with a full coilover.
#278
I've search around but really don't know that much about how shocks change how a car rides, manly because the race I'm doing limits me to stock struts. the main question i have is what will happen if i put really stiff springs on stock struts could it make my car actually handle worse.
thanks
thanks
#279
Ek Forever y0!
Yes it could, to a degree. It's really critical that the shock be appropriately damped for the rates you use.
If you're limited to stock shocks, you should stick with rates similar to stock. Tein S. tech or H. tech would probably be alright.
If you really want the car to handle well, you really need to focus on tires and anti-roll bars.
#280
ok thank you.will be using track tires and I've heard removing the front anti roll bar can increase performance, its something i will test but any opinion.
how much of a drop on stock shock can i do before i start to chance blowing them out.
thanks
thanks
#281
Ek Forever y0!
Once I switch from 350lb front springs to 550lb front springs, I'll probably remove my front swaybar.
It just depends on your driving ability, taste, etc. Some people prefer a little understeer.
#283
Hey, New to Honda Tech. And I have a Del sol on Tokico Blues with some no name coilovers. And I was wondering if I should get tr Skunk 2 coilover sleeves or the GC coilovers.
Also correct me if I'm wrong but the 94-01 integra suspension is the same as the del sol? They share the same components .
#284
i was considering some kyb agx with megan racing coilovers there 325F 300R. any other considerations would be nice too.
#286
can you share some thoughts about the blox 21mm rear sway bar and asr subframe in an ek chassis? i was about to buy a blox 21mm rear sway bar from this guy but he said if i use an asr or bwr subframe the bushing locations don't work well with blox sway bar on either of the subframe. he said the bushings will be on a curve part of the sway bar and it will slide off center..is there a remedy for this make it work? thanks!
#287
Ok, one question, for the srt.t, they have perch's on them, will I still be able to use the GC's coilover kit or do i have to manually cut the perch's and install the GC?
#289
Ek Forever y0!
You won't be paying much more if you got an ASR bar and subframe brace from a good dealer like THMotorsports.
Also, BWR subframes have had fitment issues in the past. I hope they've resolved them. Not too many companies are excited about taking returns, not to mention the pain in the *** of shipping it back and waiting.
#290
#291
The Grumpiest
There are two kinds of G/Cs. One for regular shocks and one that is Koni specific. Have you even gone to the Ground Control website? Googled pics?
#292
However, seeing that the str.t have perch's, I was thinking that the kit would not be able to fit in with the str.t
(STR.T 8050 both front and rear)
#293
Turn them to full soft, drive around, notice that the car feels under damped (it's bouncy). Turn the front shocks up slightly, drive some more. repeat until it feels over damped, and then back off slightly from that setting. Repeat procedure for the rear.
#294
Libertariat,
I am going to purchase a Koni/GC combo for my Del Sol as was set on around 425-450F and 325-350R after reading your posts and others. I decided to ask THMortorsports since they posted this on the first page of their sponser post and would like to get your feedback:
On page 1, THMotorsports posted this:
Our Ground Control Rate Suggestion:
Street Use Only: 290/350Lbs
Street/auto-x: 350/380Lbs
Street/Road Course: 380/450Lbs
Is that FRONT/REAR or REAR/FRONT? Most people suggest the fronts to be higher than the rears since the engine is in the front...
---End Quote---
Its F/R. Since its a FF car, they are prone to understeer. Having a higher spring rate in the rear helps to car to rotate and counter-act the understeer offering a more neutral feel.
Thanks in advance,
Nick
1-800-959-0145 ext 103
Nick@thmotorsports.com
AIM: NickGTHM
www.thmotorsports.com
---End Quote---
Thanks in advance,
Nick
AIM: NickGTHM
#295
Hi, I was just wondering when it is recommended to get top hats for the koni/gc combo. I know you generally cut the oem but is it necessary to upgrade?
I won't be slamming my car or anything, maybe 2-2.5 inch drop max. It will be a daily/HDPE car.
Any info on this would be great. Thanks
#296
Ek Forever y0!
Top hats are only warranted on a really slammed car. Any mild drop won't need them. You're fine.
#298
Libertariat,
---End Quote---
Thanks in advance,
Nick
AIM: NickGTHM
---End Quote---
Thanks in advance,
Nick
AIM: NickGTHM
#299
Ek Forever y0!
I'm honestly not sure what you're asking. Maybe I'm not reading it right, but I think you'll have to clarify.
#300
Ok, THMotorsports stated on the first page of their thread selling the Koni/GC combo that they suggest the following spring rates:
I then asked if that was F/R or R/F because most posts suggest a higher spring rate in the front due the the added weight of the motor. TH however says this:
What I am asking is if you could comment on this - thanks!
