Brake Upgrades for 96-00 Civics, applicable to some older Civics and Integras
#77
Daisy... Daisy...
#78
Re: Brake Upgrades for 96-00 Civics, applicable to some older Civics and Integras
Can we get the orginal upgrade chart on the first page restored to this thread.
#79
Hello BrakeExpert,
I am an hungarian Honda Fan and I would like pick up some information.
Do you know german brand ATE? If yes this aftermarket part reach the Honda's original level?
#81
I picked up a set of DA rear trailing arms. I read on your first post that they will work but the center bushing isn't the same. Do I just replace that with a 99-00 civic bushing? does it need to be a rear disk bushing or are they all the same? Honda doesn't have it as a part number anymore... any info on where I can get one then?
thanks
thanks
#82
Im having some fitment issues with my front setup.
I have 96 ITR 4x114.3 front spindles, 23T brackets and 17CL15VN Calipers from a 99 TL with the Prelude VTEC rotors. I bolted it all together just to try to see where I had to grind the caliper bracket, however I dont think its required when using the ITR hubs. Doing so would actually move the outer part of the caliper into the disc and my setup is already touching.
Would I be better off swapping the ITR hubs into my ex spindles and grinding the caliper bracket or using a shim under the caliper bolt?
Heres a pic of my setup.
#84
so if i read right, i can get the rear disc brakes off a 92 eh9 and put them on my 97 ej6 by just getting the spindles? and would the e-brake cable end from my drum brakes fit onto the disc brake lever(or whatever it attaches to)?
#85
ok so dont answer the last question, figured it out...
but now my question is will abs rear discs work on my car wich has no abs
#87
I took ABS equipped rear disc off a 01 GSR and just removed the ABS sensors and bolted them on my car. I have a 2000 LX civic and have had them for 2 years and had no problem. My car has since been stolen and stripped, but I'm keeping with the same setup outback and pieceing together my front brakes with S2k calipers.
#90
Daisy... Daisy...
#91
Hello i am from Mexico City and we donot have itrs were can i buy this for a civic sir want to have 4x100
BrakeExpert
Suspension & Brakes
442
11-27-2023 09:33 PM
Redline96LX
161
05-05-2021 09:46 AM
BrakeExpert
62
09-29-2009 11:54 AM
