rear camber
rear camber
1999 ek coupe w rear disc brake from 2000 si. I have blackworks coilovers, lcas and subframe brace. It does have rear camber kits. My question is the right rear has to be adjusted at least 2.5 inches longer then left rear. As far as I know or can tell nothing looks bent or damaged. Any indeas?
Re: rear camber
I actually really did mean inches. I'm not sure what the exact number is as far as camber goes. Physically looking at the adjuster one is that much longer then the other. When you say it's damaged, are you saying the frame is.damaged and needs to go a body shop?
