brake pedal pressure loss
Anyone ever had an issue where you lose most of your brake pedal pressure after turning your steering wheel all the way in either direction. Usually when I'm backing up or making a sharp turn ill lose pedal pressure till I hit the brakes a few times. Its the only time it happens. Normal driving and brakes work fine. If it were the brake master cylinder it would be a constant problem in my experience. Thanks in advance.
Re: brake pedal pressure loss
Booster may be weak
