Blox Lca
#51
Re: Blox Lca
The same failure as the old bushing. I don't have the details of it - probably on another forum. But note I'm saying "heard" as opposed to "my personal experience."
#52
Re: Blox Lca
thanks smokingcoop for the installation tip! recently got a good deal on some blox lcas and the bushing stories were driving me crazy as well.
Hopefully all goes well!
#53
Re: Blox Lca
I replaced the bushings on my Blox LCAs before I even installed them. The Hardrace OEM replacements fit right in with the ball joint press I rented from O'Reilly.
#54
#55
Re: Blox Lca
No they're not (as least for my 96-00 LCAs). I cut out the Blox ones and they measured the same diameter as OEM. Any pics I have would look just like OEM bushings.
#56
Re: Blox Lca
Get F7's. The end links do NOT line up with what you have. To my knowledge, only Function 7 and Skunk 2 have holes in the proper place (along the top, center) to line up with the sway bar end links.
#57
Re: Blox Lca
That is another issue with blox control arms for 92-95 civic, and 94-01 integra. The endlink holes are in the wrong spot. You are basicly required to use adjustable endlinks.
#58
Re: Blox Lca
Again, that's not an issue with the 96-00 Civic arms. Everything lined up identically to the OEM arms when I compared them and they work fine with my endlinks.
#59
#60
#61
Re: Blox Lca
EK Blox LCA.
I have been through about five of these posts on different sites. The Blox control arm is a good part but those bushings are garbage. The rubber in them is way too soft. So, I get that the shock bushing hole is OEM size. And I see that people have installed better outer bushings. But I still have not seen any part numbers for any of these bushings from someone who has actually done it.
#62
Re: Blox Lca
EK Blox LCA.
#63
Re: Blox Lca
Oh I missed that. So no info on the EK LCA's? The outer bushings are definitely not the same size as stock. This is why I am researching a better replacement.
#64
Re: Blox Lca
Hard Race #6103. They are OEM sized replacements that I used to replace all the bushings in my 96-00 Civic Blox LCAs.
You obviously like to argue since that was from 8 months ago... Some people don't seem to understand or learn things for themselves and keep repeating internet hearsay, so I was only stating facts for the people who can't figure them out.
