BEST COILOVER SLEEVE ON THE MARKET
Just wanted to see what you guys are using or what company you think makes the coil over sleeve on the market. i personally ran sk2 sleeves for 2 season with blues ran perfectly fine. just grabbed a set of megans for a wholesale price ima try those out on my street car. but wanted to see what you guys suggest. and please i know a complete coilover works the best but im asking a pacific question.
Re: BEST COILOVER SLEEVE ON THE MARKET
i like my GC's
Originally Posted by jdmb18hatch
(Post 43003068)
i like my GC's
X 213465432164164654 |
(Post 43003068)
i like my GC's
But, if I had known that Koni sells sleeves for the Sport (Yellow) shocks, I would have simply bought those instead. |
I agree with above, Ground control coilovers are the best slip ons.
Originally Posted by 98civdx
(Post 43003896)
Originally Posted by TunerN00b
(Post 43003342)
I love my GCs as well.
But, if I had known that Koni sells sleeves for the Sport (Yellow) shocks, I would have simply bought those instead. The Koni-sleeves are also not only specific for Yellows, they have sleeve-fitments for all their dampers. Extra benefit of GC (in case of Yellows) could be considered to be that you get from them a one-brand package: sleeves + extended top hats (+ springs) and an arguably good looking-one. |
custom ground controls per the application with koni dampers :thumbup:
Kristo- very true, but gc sleeves look better then other sleeves ;)
My post^^ amended accordingly :)
Originally Posted by kristo
(Post 43005049)
The Koni sleeves have the benefit of being Koni-specific - like the GC Koni sleeves, but you need a (Koni supplied) adapter to use 2.5" springs, and the locking method is different (better/worse?) from GC.
These were the only coil-overs I could find on the Koni website.
http://www.koni-na.com/1150.cfm Are these the slip-on sleeves you were talking about? To me they seem like these have threaded shock bodies, not the slip on type. Where can you get the sleeves? |
(Post 43005588)
bsmith100, these are what we are talking about http://cgi.ebay.com/ebaymotors/GROUN...Q5fAccessories |
(Post 43006897)
(Post 43005049)
The Koni-sleeves are also not only specific for Yellows, they have sleeve-fitments for all their dampers. |
ohhh, go to weaksuace or thmotorsports, they do sell koni specif gc sleeves.
Koni doesnt make them, its just a option that ground control has. |
(Post 43006995)
(Post 43005049)
(Post 43003342)
Originally Posted by bsmith100
(Post 43007116)
I don't think that is what they were talking about. In their posts they refer to the Ground Control sleeves specifically for Koni that take the 2.5 inch springs, and then they talk about the Koni built sleeves that take smaller diameter springs and require a special adapter from Koni so they can use 2.5 inch springs.
Ground control makes sleeves for many different types of shocks, not just koni.. There are adapters to use non koni sleeves on koni shocks, this is becasue of the cir clip. The koni spec gc grabs the cir clip. In there post they may be talking about the koni cir clip, if you dont have koni spec seleves you will need an adapter for the sleeve to sit on top of and grab the cir clip. I have never heard of koni making sleeves, only ground control making them for koni. But your post is a little confusing sorry. |
(Post 43007313)
(Post 43008144)
Yeah, I had not heard about Koni selling their own sleeves either. Although some of the posts seem to suggest that they do. Or at least that was the impression I got.
I belive they sell there own adapters to run a skunk2 or something sleeve on there shocks, but again, im not 100% positive. |
TunerN00b and myself were indeed also talking about sleeves made by Koni.
See their catalogue here and relevant webpage here. http://www.kingmotorsports.com/image...medium/373.jpg http://farnorthracing.com/newimages/...Webgraphic.jpg |
no love for megan's?
No.
Looks like the gc ones, well just black
(Post 43012285)
http://farnorthracing.com/newimages/...Webgraphic.jpg will radically reduce side bending loads on the shock shaft, since they keep the spring parallel to the shock (unlike stock upper shock mounts). But then again, those are also shown with helper springs, which most people don't bother to run. |
is there any advantages over just a koni/gc setup?
Other then the top hat, I haven't ever seen a top hat like that. |
