2000 Honda Civic Si Pure Stock.
I’m racing my Civic Si on a 1/3 mile oval asphalt track. As the name of the division states “Pure Stock “. My question, is there anyway at all to get some camber, castor and toe put in the car?. There has to be some ways to do this.
Thanks! https://cimg8.ibsrv.net/gimg/honda-t...8ffa4e8fe.jpeg |
Re: 2000 Honda Civic Si Pure Stock.
Nothing?, I thought thee were Honda experts on here.
Really depends on the parameters they will allow to keep you in the class you are in currently.
Adjustable control arms up front. Aftermarket adjustable toe arms on the rear. But at this point wouldn't be stock. If you needed more positive camber in the rear, you could do the washer trick on the rear.. Look into SPC adjustable suspension parts. https://www.carid.com/2000-honda-civ...lignment-kits/ |
You can bend the stock parts which would be considered cheating. That's it.
Originally Posted by black94sol
(Post 51946395)
Adjustable control arms up front. Aftermarket adjustable toe arms on the rear. But at this point wouldn't be stock. If you needed more positive camber in the rear, you could do the washer trick on the rear.. Look into SPC adjustable suspension parts. https://www.carid.com/2000-honda-civ...lignment-kits/ Thanks for the info. |
Originally Posted by Andrew Packer
(Post 51946590)
Is there any info online about the washer trick?
(Post 51946666)
Basically buy some longer grade 8/10 bolts, and add washers between the camber arm and the chassis. Torque to spec
You need Class 10.9 (metric) flange bolts in a 1.25mm pitch. I believe they are M10 for the rear UCA.
May be kinda tough to find. Honda uses weird thread counts. Class 8.8 will not work. They're not to be mistaken for "grade 8". Strange that you want POSITIVE rear camber, however. You just want the thing to rotate, I'm guessing? Too bad there's no "stock" way to add a lot of front camber. That's where the cornerning speed is at. |
https://cimg4.ibsrv.net/gimg/honda-t...6910d8d19f.png
Originally Posted by B serious
(Post 51948162)
