Suspension & Brakes Theory, alignment, spring rates....
[FAQ] Shock Dynos
Old 11-06-2005, 05:33 PM
  #276
slammed_93_hatch's Avatar
Default Re: OFFICIAL: Shock Dynos (azian21485)
the bottom two graph's are mine.
There was some confusion when i had them dyno'd the person running it thought that the settings i had them at were somthing i had been running, and that lead to me needing to change the labeling.
I don't know what type of dyno, the place i went to uses, i will try and figure it out. (the layout looks the same from the top one ot mine but ill ask). I do know that my koni's from side to side were pretty darn right on close.
Also these koni's were done at the Runoff's, for another HT user who was planing on using them on his AutoX GSR or LS integra. The car was wrecked, befor the koni's were ever put on, and i bought them from him. (so the dampers were valved at the 05 runoff's).
Old 11-21-2005, 10:42 PM
  #277
J[5]D[6]M[2] GSR's Avatar
Default Re: (MNsnowdaboy)
What are good Performance springs for a 00' GSR DC2?? I know the Tein- S tech are good for looks but i want more performance...
Old 11-22-2005, 08:56 PM
  #278
Cory Matthews's Avatar
Default Re: (blkGEESR)
you guys should really think abot resizing the pictures to all the same size so its easier on the eyes.
Old 12-30-2005, 09:21 AM
  #279
96b18c's Avatar
Default Re: (z6 coupe)
anyone have dynos for the T1R coilovers? trying to decide between the T1R's, a ground control/koni coilover, or the zeal s6 coilovers and have only heard good things about the T1R's but don't have any dynos to check out. thanks.
Old 12-30-2005, 09:30 AM
  #280
.RJ
.RJ's Avatar
Default Re: (96b18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96b18c &raquo;</TD></TR><TR><TD CLASS="quote">anyone have dynos for the T1R coilovers? trying to decide between the T1R's, a ground control/koni coilover, or the zeal s6 coilovers and have only heard good things about the T1R's but don't have any dynos to check out. thanks.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1028280
Old 12-30-2005, 10:04 AM
  #281
96b18c's Avatar
Default Re: (.RJ)
I didn't even know they made those. I think they are the newer versions but I was referring to these...https://honda-tech.com/zerothread?id=1470253...that are different.
Old 12-30-2005, 10:36 AM
  #282
.RJ
.RJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96b18c &raquo;</TD></TR><TR><TD CLASS="quote">that are different.</TD></TR></TABLE>
Well I'd put money on the damping characteristics being the same, as well as the range of adjustment
Old 02-05-2006, 05:53 PM
  #283
Jason C SBB's Avatar
Default Koni, Tein, JIC dyno plots
Koni, Tein, and JIC, for miatas, interesting stuff:
http://forum.miata.net/vb/showthread.php?t=166909
http://forum.miata.net/vb/showthread.php?t=167890
Old 02-06-2006, 01:11 PM
  #284
Default Re: Koni, Tein, JIC dyno plots (Jason C SBB)
something is funky with the way they had there dyno set up. its showing the forces wrong, it should be flipped. (adjustablity of koni's is in the positive force, not negative)
Old 02-06-2006, 06:09 PM
  #285
CRX Lee's Avatar
Default Re: Koni, Tein, JIC dyno plots (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">something is funky with the way they had there dyno set up. its showing the forces wrong, it should be flipped. (adjustablity of koni's is in the positive force, not negative)</TD></TR></TABLE>
Most of that is simply the way the dyno data is set up to print out so you can flip the graphs around in several different ways to fit your preference or what you are used to looking at. After being used to read it printed one way, sometimes it takes a moment to straighten out if it is printed another way.
We had this Miata thread pointed out to us by several people but decided not to participate as there is a great mix of correct and incorrect info and interpretation. These discussions seem to gain a life of their own and can head off in many different ways often with limited bearing on how things really are. One similar valving comparison thread went 40+ pages on VW Vortex and we followed it mostly for the laughs of how far from reality it went. The problem is that once you step in, it is very hard to get out and there are enough self proclaimed experts with any number of agendas or even the best intentions that get led astray that it is easier to not get started. As a manufacturer, it is even harder because people also project that what you might say is sales pitch, spin or damage control. That is one reason why I rarely post in this thread as well, it is simply better for me not to.
If I may, I would suggest that one look at the any data you like and be careful to make sure about the context it is used in and don't necessarily take as gospel what some people say that it reflects or shows. Be even more aware that assumptions from that reading may not necessarily be correct either and an assumption based on a generality with a little off kilter frame of reference and maybe some dead wrong information and you can be operating way off in left field without ever knowing it. Take in what you like and see how it fits your model of what you understand and what your experience proves out to you as well. If it works, keep going but be ready to step back a bit if something seems off. In short, don't beleive everything you read and back it up with what works for you and fits with your own experience. Good luck!
Old 02-07-2006, 07:01 PM
  #286
Honda-Tech Platinum Member
Setsuna F Seiei's Avatar
Default Re: Koni, Tein, JIC dyno plots (CRX Lee)
How about the 6-way omni?
Old 02-07-2006, 07:21 PM
  #287
heel_touge's Avatar
Default Re: Koni, Tein, JIC dyno plots (BrokeAssPinoy)
has kendel put up the dyno's for the ohlins PCV's yet?
Modified by 1slowcivic at 3:48 PM 2/9/2006
Old 02-21-2006, 12:03 AM
  #288
Default Re: Koni, Tein, JIC dyno plots (1slowcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowcivic &raquo;</TD></TR><TR><TD CLASS="quote">has kendel put up the dyno's for the ohlins PCV's yet?
Modified by 1slowcivic at 3:48 PM 2/9/2006</TD></TR></TABLE>
why don't you send him a PM
Old 04-05-2006, 07:25 AM
  #289
dFreezy's Avatar
very informative thread, i wish we could see some more models at the top
Old 04-11-2006, 01:51 AM
  #290
hazard_one's Avatar
Default Re: OFFICIAL: Shock Dynos (slammed_93_hatch)
does anyone have shock dynos for those form and function coilovers?
Old 04-12-2006, 11:36 PM
  #291
Default Re: OFFICIAL: Shock Dynos (hazard_one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazard_one &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have shock dynos for those form and function coilovers? </TD></TR></TABLE>
they are Relativly new so i don't think so. You might want to contact them and see if they can provide you with one.
If they want to have a set done, i can provide the service, or "vtecvoodoo" can, or RJ. has offered to pay for shipping to have them done by CRX LEE at Koni.
Old 04-13-2006, 04:51 PM
  #292
Mike_C's Avatar
Default Re: Koni, Tein, JIC dyno plots (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">i wish we could see some more models at the top</TD></TR></TABLE>
yeah i suppose i could do that tomorrow.
Old 04-19-2006, 08:47 AM
  #293
dFreezy's Avatar
Default Re: Koni, Tein, JIC dyno plots (Mike C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">yeah i suppose i could do that tomorrow.</TD></TR></TABLE>
Old 05-15-2006, 10:03 AM
  #294
i0o0ll0o0i's Avatar
I'm curious, how would stock suspensions look on these graphs?
Old 06-07-2006, 11:03 AM
  #295
SnoMan's Avatar
Pretty cool stuff but... how do you read them??
Old 06-28-2006, 09:59 AM
  #296
stealth_EK4's Avatar
Default Re: (SnoMan)
anything on skunk 2 coilovers for DC?
Old 07-13-2006, 04:13 PM
  #297
XzzRzzX's Avatar
Default Re: (stealth_EK4)
Maybe i could see if i could get a dyno plot of one of our jrz 4 way adjustable shocks...They are really inpressive, We also rebuild them at our shop, Which i was told is a black art of suspension Not alot of people know how to rebuild them...
Old 07-15-2006, 04:13 PM
  #298
EJ6_ROY's Avatar
Default Re: Koni, Tein, JIC dyno plots (i0o0ll0o0i)
x2
Old 07-27-2006, 08:48 AM
  #299
billball's Avatar
Default Koni Question
Great thread here. I have a Koni question. Called their tech line and did not get a definitive answer. Have sent an email to Lee, but have not heard back yet.
BTW, I do not have a Honda, so sorry for invading here, but I need an answer and this seems like a good group here. If this is the wrong place to put this query, I will delete/move it.
Here we go:
When setting the rebound damping on your shocks what would you make of a shock pair in which the shocks have vastly different extension times at the same setting. I just got a replacement set from Koni after my others went bad, and here's what I observed: Set full hard on rebound, shock #1 took 48 seconds to extend while shock #2 took 26. Set 1/4 turn off full-hard, it was 36 and 22 seconds. To get #1 to 22 seconds, I had to set it at 1-1/4 turns vesus 1/4. Hmmm...
This seems real odd, but the call-in Koni tech did not say anything specific. Of course, a dyno would help. Any place in either the Contra Costa County or the Fremont/San Jose CA area?
I could send them back to Koni for a check, but I'm running out of time getting ready for an event. What would you do?
BTW, this was the rear shocks. The fronts did not exhibit this problem.
TIA,
Bill
89 Porsche 928 S4 supercharged
http://billsworkshop.com/P928S...2.mp4
Old 07-27-2006, 09:39 AM
  #300
Mike_C's Avatar
just updated 1st post
Quick Reply: [FAQ] Shock Dynos
