Storage Cleanout!! B-series LS-T Partout & more
Trying to clean out some of my extra stuff in storage for more space. I have plenty more that I will add when I find it. Since alot of it is packed in boxes I'm lacking some pictures but I will update as much as I can each time I go out there. Thanks for looking and feel free to PM me or text me @ 214-766-2517 if you are serious about buying. Thanks. I am open to trades as well.
Brandon
1. OBD1 LS b18b motor. Completely torn apart, was going to rebuild, will need hone/deck/mill more than likely. I have all parts labeled and in boxes. Comes with block, pistons, rods, mains, head, valves, rockers, seats, springs, retainers, valve cover, cams, gears, oil pan, etc. Probably threw away the water pump but might have it still. WILL NEED COMPLETE REBUILD since it is torn apart completely. Never raced or beaten on. Sold my old motor to a buddy and took this on as a partial trade. Was bone stock when I got it. Asking $250
2. B-Series turbo kit. Complete minus wastegate and fuel setup. Made 402whp/320wtq on my bone stock ls motor with 1000cc injectors and s200b.
Rundown:
-XS Engineering TO4X turbo - had rebuilt a few years ago but its been sitting in storage so might need new seals
-Maxrev stainless log manifold (Flanged for tial 35mm or 38mm)
-Custom 3" downpipe with flexpipe and 3-bolt end exhaust flange
-Dumptube
-Greddy large FMIC (type 24 I believe) - Couple dings/dents etc, but holds pressure fine and works great
-Custom 2.5" charge pipes
-HKS blow off valve
-All silicone couplers and fast-turbo clamps
-Stainless braided feed line with a/n fittings. (i believe -3)
-Stainless braided return line with Earls fittings (-10)
-Golden Eagle vacuum distribution block
-Turbo XS manual boost controller
-GM 3bar map sensor
-All vacuum lines also included
Asking $1275
3. ACT Xtreme Pressure Plate w/6-puck unsprung disc and Fidanza 8lb flywheel. Used around 1300 miles. Asking $360
4. STR sheetmetal intake manifold for LS motor with Hondata heat gasket. Fuel rail holder has to be tack welded back in place. (pictured below) Throttle body not included. Asking $285
5. MSD 6al w/blaster coil mounted in custom aluminum tray (mounts in factory battery location) with OBD1 LS distributer w/ MSD cap, wires, and coil wire. Asking $375
6. Hasport 70a compound polished mounts for b-series in 92-95 civic/94-2000 integra. SOLD!!!!!
7. B-series axles and intermediate shaft. Asking $150
8. B-series shift linkage and shifter. Asking $85
9. Ken's Custom Chassis 10pt Cromoly cage for 92-95 Civic Hatchback. Paid close to $800 plus shipping. SOLD!!!
10. LS obd1 ECU socketed for Hondata s200. Asking $70
11. LS obd1 ECU stock. Asking $65
12. OBD2 oem b20 throttle body includes all sensors. Asking $50
13. 1997 del sol sohc non vtec ecu D16y7. Asking $50
14. 1999 civic dx sohc a/c lines. Everything in engine bay. Asking $50
15. OEM Honda wheel lock kits. All sets are used but in great condition. Have 19mm sets and also 22mm sets for Pilots/Odysseys. Asking $20 per set
16. 14" Integra Steelies with Hubcaps. Falken tires with edgewear. Good rollers. Asking $110
17. 3rd gear mainshaft gear set for TSX/Element. Brand new. Asking $130
18. Bieffe helmet. Had for a while, barely used to drag race at track. Dot approved but I'm sure everythings outdated. no bag or shield. Asking $50
19. OEM fluids. Tons of it. Brake fluid, PS fluid, VTM4 fluid, Dual Pump, Brake cleaner, washer fluid, throttle body/intake system cleaner. PM for prices.
20. Apexi EL Tach w/shiftlight. Works perfect. $120
Brandon
Rundown:
-Dumptube
-HKS blow off valve
-GM 3bar map sensor
Asking $1275
