FS: OEM Power Window & Mirrors Conversion EF, CRX, Civic, Sedan
OEM Power Windows w/harness + 4 fuse holder + switches $150
Came off a EF Civic Sedan LX, believe it was a 91. Comes with a complete setup; minus the rear actuator, other than that it's the entire setup. Perfect for Civic Wagon setup with just two pieces needed to complete the rear OR for your CRX Si HF Std model.
Harness is basically uncut, besides what you would wire up for power/ground, comes with the 4 fuse holder to attach under the dash to OEM fuse box, and includes the power window switch both driver and passenger. Also comes with all the nuts/bolts!!
CRX install resource: CRX Power Accessories Saga (2 yr update!)
Civic Wagon install resource: Power windows and locks here I come!!!
OEM Power Mirror + switch + interior guard/cover thingy $85
Same as above. Came off a EF Civic Sedan LX, believe it was a 91. Comes with mirror + switch; uncut. Also the inside mirror cover piece thing; where the adjustment **** thingy used to be. Could use a nice touch up to the outside casing to look like new.
Civic Wagon install resource: Can't remember check Honda-Tech or Honda Civic Wagon forums, sorry
Personal Message me for anymore info needed
Phone can't receive calls at all only texts
Text ONLY anytime: 1-(661)-524-6150
Re: FS: OEM Power Window & Mirrors Conversion EF, CRX, Civic, Sedan
Double posted this ad somehow. Mods/Admin lock or delete THIS thread I guess....
Original FS post is here: http://www.hondamarketplace.com/show....php?t=3037651
