FS: 94-01 Integra Ground Control Honda Tech Kit with RACE Koni Yellows
94-01 Integra Ground Control Honda Tech Special Kit
626-940-7748 or email: Lukaono@hotmail.com - I prefer text
$1000 SHIPPED 48 States only
What's special about this kit is that the Koni's are the RACE revalved shocks made for spring rates higher than 600lbs. Kit comes with everything in the Ground Control Honda Tech Special Kit and the Koni RACE shocks (they were $100 extra EACH). I ordered them with two 500lbs springs and two 700lbs springs. I bought them last May and installed them on my car with plans to track the car. I never tracked it, drove it MAYBE 100 miles and just took them off when I sold the car. They are pretty much new.
Here's the description from Ground Control:This kit fits the '94-'01 Acura Integra. The kit will allow you to lower your car up to 3.5” without the worry of constantly bottoming out. The included Honda mounts increase available shock travel 1” over the stock mounts.
This kit includes:
2- Single adjustable front Koni shocks (RACE)
• Top adjustable.
• Valved for a great ride and improved handling
2- Single adjustable rear Koni shocks (RACE)
• Top adjustable.
4- Ground Control Eibach springs
• Designed by ground control made by Eibach.
• Barrel shaped for increased spring travel
4- Ground Control Honda upper mounts
• Ground control upper mounts are designed to extend the travel of your shock an inch above stock, reducing the chances of bottoming.
4- Ground Control bump stops
• Manufactured exclusively for Ground Control in Germany using proprietary closed cell foam design. This reduces harshness and increases the life of the bumpstop.
This kit includes:
• Top adjustable.
• Top adjustable.
Re: FS: 94-01 Integra Ground Control Honda Tech Kit with RACE Koni Yellows
Damn its too bad the spring rates are so high or I'd seriously consider these to replace my tired older Koni Yellows.
Price reduced to $1000! OBO Please make offer if you're interested! I can also part out springs and konis.
