Looking for a machine shop in hesperia applevalley victorville high desert area.
No-Traction = Fun
hey all you high desert rats. I'm looking for a good machine shop up here in the hesperia applevalley or victorville area.
I'm going to rebuild a B18C1 I picked up.
I need to do the following,
Head:
-pressure tested
-cleaned out
-3 angle valve job
-new valve seals
-and resurface
block:
-Hot Tank
-Hone all Cylinders
-Deck'd
-crank micropolished
Head:
-pressure tested
-cleaned out
-3 angle valve job
-new valve seals
-and resurface
block:
-Hot Tank
-Hone all Cylinders
-Deck'd
No-Traction = Fun
Re: Looking for a machine shop in hesperia applevalley victorville high desert area.
I pulled the pistons and rods out of the bottom end and cleaned them up. They look like there in great condition and I was wondering if I can/should reuse them. The block was a 2001 not sure how many miles. It had a bad rod bearing.
No-Traction = Fun
Found a local shop and was told the rods need to be cut and re-sized back to spec. $20.00 each
Hey, How much did they charge to rebuild your bottom end? Where is the shop located at bro? and What was done to it and how much did they charge.... i need a shop.... Thanx bro.
i live around the same area would like too know 2 got a 90 LS da block and 94LS block
760 HI DES
760 HI DES
No-Traction = Fun
Arringdale's Engine Rebuilding
11918 I Avenue
Hesperia, CA 92345-4945
(760) 948-5155
Ask for Rick & tell them David G sent you!!!
11918 I Avenue
(760) 948-5155
I've used Arringdales with great results. 100k on my D15B7 and still going strong. I plan to be a repeat customer.
DefiantGSR
18
01-29-2005 11:43 PM
98civicEX
11-05-2002 05:57 PM
acura, apple, body, desert, engine, fabrication, high, honda, integra, machine, performance, shop, shops, valley, victorville
