engine swap, what is a fair price?
Hello, I am new to H.T. I have a 94 eg hatch. Looking to put a stock GSR Eng. What is the going price for labor? I am in So. Cal. Thx.
Re: engine swap, what is a fair price?
Thank Asian, unfortunately I don't have the resources or the time. Can you guys recommend any good shop specialized honda swaps in So.Cal. ? Thx.
damn. for as easy as swapping a honda motor is, 400 even seems like a shitload to pay. i've never done a swap before and honestly the **** isnt rocket science. i guess thats right given how outrageous labor is today though.
maybe youd be better off finding a friend that would do it for cheaper? or better yet if you could find the time one that would just help you with it.
Shops charge between $400-$800 and good luck getting a prediction on when they will actually get around to doing the swap. Your car could sit around fro weeks b4 they actually decide to work on it. Your better off just doing it ur self.
Here is a basic crash course.
Un hook battery terminals
Remove Axels
Un do shift linkage
Un do exhaust
Drain radiator
Un hook radiator hoses
un plug wiring harness from motor
un plug wiring harness from ECU
Un hook Fuel line from Fuel rail
Hook up Cherry Picker
Un do motor mounts
Lift out motor
Start process in revers with new motor...
Remove Axels
Un do shift linkage
Un do exhaust
Drain radiator
Un do motor mounts
Lift out motor
Just get a buddy and both of you Learn as you go , you can find EVERYTHING to do a swap on the internet , thats what i did and also did a swap for a buddy .
Only thing i Took my car to a shop for was to wire it for Vtec and just to make sure everything is on Right goodluck tho
The going rate for a R&R of an engine is ~10 hrs according to Mitchell On-Demand which is what most shops around here use for estimating. Shop rates are anywhere from 75/hr to 130/hr depending on the shop.
I do side work, PM me if you are interested.
A I had well known guy from socal do my H22! Complete engine swap on my car.. he replaced all seals and did a timing belt, water pump and valve adjustment as well as replace the clutch.. pm me if you want his number.. btw he had the old engine out and the new H22 in and running in 8 hours
GDD Black Reject
Me and 2 other guys would do ur swap for prolly 800. vouch by King and Pilot. we just did my swap just look at my build thread
EJ8_Enthusiast
13
09-26-2008 02:49 PM
