wtt/wts 94 dx coupe with d16y7 north alabama
Re: wtt/wts 94 dx coupe with d16y7 north alabama
well im not 100% sure. i keep adding new parts like every other day. id say $2000.00 i may be way off but im just looking at what i have in everything, yet this car still needs some tlc on trim pieces and stuff, paint isnt perfect. just trying to be up front
I HAVE A 91 CRX HF WITH A SI CRX MOTOR IN IT IF INTERESTED IN TRADE PM ME AND I CAN SEND YOU SOME PICKS AND MORE INFO
I got a 91 Si hatch with an ls swap,crx dash, but needs paint. Sunroof still works good. we can work a deal.
I'll be honest dude it looks like crap. But it runs tip top. Motor has got about 55k on it. New t-belt and water pump,axles,v c gasket. The last pic is how I bought it not running. Has a horrible primer job over orange flake paint. I got new door panels and alot of other stuff for it. I just logged my gas mileage and it gets 35 on average. No ac was removed by the tool that had it. I have'nt had it that long but planned to have it resprayed soon. All thats left to replace is the fenders. I replaced the bumper, got signal lights for it and replaced the euro tails that were on it.
i see what your saying on that last pic. ha ha pretty rough, but thats how my coupe was. i just resurfaced the front rotors today and replaced the brake fluid, so braking is awsome now. Umm i'm not really sure about the trade just simply because of the paint, ha ha. what color is it originally. I would probably like to see it, or see some detail shots of the interior, the motor, etc. how do little things work like the windows, hatch shocks, etc. any and all info you can share would be helpful.
what all does it need to get the ac working, i am interested, just need to know more. you may want to text me, it would be easier
Yeah I should probably do that instead but i'm using a phone I hate to text with. It was originally red, then they painted it orange/w/flake. It was actually painted really well. door jambs hatch jamb and all just not engine bay they flat blacked that. Then they flat blacked the whole car. But they sprayed it really thin so my uncle who paints cars said it would'nt be hard to sand. I thought it would be alot of trouble but he seen it and said no problem so I bought it. Windows both work smoothly. Ac needs pretty much under hood stuff. Compressor, condensor, and lines. Climate control is still crack free. I'll get some other pics of the stuff you need. I took out the carpet and cleaned and re-dyed it when I swaped the dash too. We just put DC brakes on the front tonight and we're swaping the booster/master this week too. All I found wrong mechanicly is it could use some tie rod ends. Oh it has a new clutch also. I'll get some more pics up tomorrow.
Ok I'll have to say I'm out on the hatch. It's got a little more work than I'm looking for and I would much rather have something with ac but I appreciate the info
It's cool. I really was'nt looking to get rid of it this early in the game i just got it, but it never hurts to ask. Good luck selling it. If you had to put a price on it how much would you want? I thought of buying a daily and making the ef a ground up build. At least you got some bumpage out of our discussion. If you want me to delete the pics off of your sale thread I will.
na your pics are fine where they are. ummm if i had an asking price, i'd say 2000. This is what all has been done.
motor swap- d16y7 with 110,000
new timing belt-oem
new valve cover gasket-oem
new intake gasket- oem
new throttle body gasket-oem
new spark plugs-oem
new wires-oem
new tires-goodrides (less than 75 miles on them)
newer amber corner lights.
new bulbs in headlights, turn signals and taillights
new window regulators-oem
newer manual rack. has 42,000 on the rack but outer tie rod ends are brand new
front rotors turned and front pads at about 8mm
rear shoes cleaned and adjusted with about 5mm
window tint removed
new window crank handles-oem
lowering springs-tms springs
new front shocks-aftermarket
brand new battery
serviced the transmission and of course changed the oil and filter.
i work for honda of decatur, so the car is always there
new timing belt-oem
new spark plugs-oem
new wires-oem
window tint removed
brand new battery
I go to decatur alot actually, my uncle lives there. I will be going that way one day this week to take my youngest son (just born) to see them I might pay you a visit and take a look at it. Is it auto or stick?
its a manual, and yeah stop in anytime, i work in the service department, just ask for Christy. Congrats on the new baby boy
ok here is the pics of my crx and the story about it i bought this car a few months ago and it was not running someone had put a crx si motor in it and couldnt get it running i put the correct computer in it and corrected the plug on the car and it cranked right up i put a new radiator, plugs, wires, and axle in the car when i bought the car they had put a new distributor, alternator, starter, and axle on the car there was new wheel bearings in the car but it dont need them what i know is wrong the car it needs a clutch bearing, tires, the speedometer doesnt work and i have a speed sensor code flashing, axle seals, and it smokes a little when you crank it but after you have run it for a while it stops and if you crank it on a regular basis it dont smoke the car comes with the white 17s on it the car is in good shape for the model the only thing wrong with the inside is the glove box is broken the outside is in good shape the only problem is i couldnt meet you any where cause the car doesnt have tags or insurance
No offense, but were you not asking 750$ for it. Then you dropped in a y7 and now your saying 2 grand. You cleaned it up, but you did not do 1250$ worth of cleaning up. Id offer 1000 for it no more. Sorry
