350whp turbo LS/Vtec with cable trans
Contact: revn9k@hotmail.com for fastest response, pics, info.
More pics in next 2 posts...
Built for easy reliable 350whp turbo ls-vtec. If you add pistons/rods it would have good potential for 500whp.
b16a Vtec head from 89 crx si dohc
b18a block
This build was just completed 4/13/14. Ready for a great drop-in swap minus fuel rail and clutch. Everything else included. Everything listed is assembled and installed.
Perfect for da integra, ef civic, or crx.
Precision 38mm Gate
Godspeed cast turbo Manifold
Precison 60-1 Turbo
Vtec solenoid w fuel gauge oil feed sensor extra
Vtec sol cover
Vtec conv kit installed
Fidanza Flywheel
Injectors 750cc rc
Valve cover
Walbro 255 lph fuel pump
ARP headstuds
ARP 2000 rod bolts
New valve springs
New oem honda head gasket
$2800 complete turbo motor with everything listed.
$3,000 complete turbo motor with everything listed and cable b16 transmission with Si gearset installed. All fresh rebuilt syncrhos rings and everything fresh. Ready to go.
Brand new oem vtec: oil pump, pickup, water pump, gates honda timing belt, oil pan.
All disassembled , hand- cleaned, built by engine builder Theng of Hickory/Newton.
b18a block
Precision 38mm Gate
Precison 60-1 Turbo
Vtec sol cover
Fidanza Flywheel
Injectors 750cc rc
Valve cover
ARP headstuds
ARP 2000 rod bolts
New valve springs
egjdmcivichatch
05-24-2012 08:40 AM
DDTECH
06-05-2011 12:42 PM
