Go Back  Honda-Tech - Honda Forum Discussion > Community Forums > Regional Forums and Meets > Southeast
Reload this Page >
new to forum. 1994 Del Sol, d15b7 engine. 1st honda... need help in North Georgia.
Southeast Alabama, Florida, Georgia, Mississippi, South Carolina
Old 08-06-2011, 08:24 AM
Default new to forum. 1994 Del Sol, d15b7 engine. 1st honda... need help in North Georgia.
Hello everyone and thanks in advance for helping me.
i bought my 1st honda last week from a friend. 1994 del sol. interior is 8.5/10 exterior is a 3/10. enjoying great gas mileage.... which is why i bought it.
Runs great! Shifts great! Smokes (white-ish blue, definitely not all white or black.... not at idle, only around 2.8K rpm) and burns oil like it's going out of style.
about 1 qt every 100 miles.
obviously looking to rebuild. would like some comments/suggestions before i start tearing into this motor.
i know there isn't a way to replace rings on the pistons with a "liquid miracle" in a can.... but would like to start eliminating the cheapest fixes first.
anyone in north georgia, lake lanier area?
i have only added engine cleaner to the oil, the idled for 5 mins and changed oil.... and added a cheaper stp oil treatment.
thanks again for your time.
alwaysthinking is offline
Old 08-06-2011, 08:44 AM
20% cooler
thenext's Avatar
Default Re: new to forum. 1994 Del Sol, d15b7 engine. 1st honda... need help in North Georg
Only way to fix it is to replace your rings.
thenext is offline
Old 08-06-2011, 09:55 AM
hafast's Avatar
Easiest way, find a motor out of the same car, tear it down, rebuild it, pull the old one and put the new one in, reduces the downtime significantly.
Otherwise, take the head off, to check the cyl bores for scoring, if damaged badly by the worn out rings its a bore to .050 or a hone to clean up the bores, then oversized pistons from rockauto or something with new rings.
Then if put together properly its all clear sailing from there.
DID ALL THIS and was not without a car for more than the time it took me to swap it.
If you are not good at anything mechanical then its as simple as taking it to someone who is.
hafast is offline
Old 08-10-2011, 10:51 AM
90 Si Hatch's Avatar
Hey what part of North GA?
90 Si Hatch is offline
Peyodie
07-28-2016 05:31 PM
my daughters
08-12-2015 02:09 AM
Reid
General Discussion and Debate
11
01-23-2004 03:31 PM
Quick Reply: new to forum. 1994 Del Sol, d15b7 engine. 1st honda... need help in North Georgia.
